1:24 Istanbul Diorama
OcCre
Catalogue # 53010D
Available from OcCre for €60,95
DSC09881.thumb.JPG.9c20b9da0241e0b507b60
If you’ve recently taken a look at our Istanbul tram review, you might like this particular review article. Yes, of course you can display your tram on a shelf, or in a cabinet, but what about outside Istanbul’s Grand Bazaar? That’s exactly what this new product from OcCre allows us to do, and with relative ease of construction. This is what OcCre have as their website product description:
“The diorama is a representation of the entrance to the Grand Bazaar of Istanbul, one of the largest in the world.
Located inside the old “walled city", on the European side of Istanbul, between Nuruosmaniye, Mercan and Beyazıt, with more than 58 covered streets and 4,000 shops or stalls, every day the bazaar attracts between 250,000 and 400,000 visitors.
The bazaar offers a wide range of products, in particular jewellers, precious metal workers, spice shops and carpet shops. The stalls tend to be grouped together by type, following the tradition of the ancient guilds. The bazaar includes two Bedestens, or domed stone-built structures, which are used for the storage of merchandise. The first of these was built in 1464, by order of Mehmet II, although it then had to be mostly rebuilt in 1864, following the earthquake.
This fabulous diorama combines perfectly with the tram of Istanbul, joining the nostalgic line of Taksim-Tunnel with the Grand Bazaar, in an effort to group two large emblems of the city of Istanbul.”
1.thumb.jpg.235f55c4c29a95ee26007dc6ef59
The kit
The Istanbul diorama is packaged into quite a plain, shallow corrugated cardboard box, with a colour product label attached. There is also a reasonable amount of weight here too, so you know there’s plenty of building material afoot. Upon opening the box, it ca be seen that the multitude of sheet material is wrapped in a heat-sealed sleeve that needs to be cut away. As the sheets in here are various sizes, and the internal box has no compartmentalisation, this is a good way of ensuring that damage risk is minimised. There are also a number of printed sheets which are rolled up, some strip timber and brass wire. A catalogue and sheet pointing to the instructions, are also included. More on the latter in a moment.
DSC09880.thumb.JPG.5f9141a76ab82fc0522ce
DSC00001.thumb.JPG.efca2eee168b0cfd7d616
The numerous sheets are made from MDF and are very neatly laser-cut. You will note how some of the parts have dovetail connections too. In essence, the entire diorama is built up from a series of wall panels that have the Islamic arch shapes that attach to them to create a 3D relief, and this is sat upon a base which is built from sections, to incorporate the ruts along which the tram lines would run. Oddly enough, there is no actual brass section strip to recreate the tram line itself, but instead, timber strip, painted silver, it what’s prescribed. Using some metal strip could be a nice enhancement, but you would need to purchase that yourself, measured against the OcCre tram wheels for best fit.
DSC00002.thumb.JPG.92bea72732b335c8709b8
DSC00003.thumb.JPG.1ccd6eb943858d10cf8a1
DSC00004.thumb.JPG.be1c747796e804e5a1fe1
DSC00005.thumb.JPG.2c73eef7374bc2a8edd59
DSC00006.thumb.JPG.e81d23b5fa6448551893c
The idea behind this diorama is that anyone can typically build it, simply out of the box contents. To decorate the walls and floors etc. a series of colour-printed textures are provided, on A4 sheets. These include stone, marble and parquet styles, and these need to be cut out to suit the various structures, and then glued into position with a glue stick, for example. Using wet glues may cause the sheets to ripple and not adhere as flat as they should, although the instructions do actually show brushed PVA as being the glue of choice. Sheets of paper are also supplied to simulate the Bazaar interior, with crowds of people and stalls etc.
DSC00007.thumb.JPG.257789dbf5561f269686a
DSC00008.thumb.JPG.7ea845907a9717ab7626e
DSC00010.thumb.JPG.e0eb4a91d0b54fb8cb7a7
DSC00009.thumb.JPG.2036c0781746020ed7cb4
DSC00011.thumb.JPG.c758f9b3c2110baddb0ee
DSC00013.thumb.JPG.05f33a3ce431c613e1b2c
When it comes to depicting the exterior details, more printed sheets are supplied, with such things as Turkish rugs, flags etc, and these can be draped over the display stands that sit outside the various stalls on the exterior of the Bazaar. These stalls also have printed awnings to shelter them from the Turkish sun.
DSC00015.thumb.JPG.9fb085e144bd2373953f4
DSC00016.thumb.JPG.27b05c4002254c85f6f66
DSC00017.thumb.JPG.331addb1adb31885da3f0
DSC00018.thumb.JPG.30e7acf249115c28d2f11
DSC00019.thumb.JPG.1f032697613f32793a83a
To recreate the road itself, then a series of strip card is supplied. This needs to be cut into brick-sized sections, and then plastered over the road in a staggered manner. You can of course then paint and infill between them and add some airbrushed staining to weather things realistically.
DSC00012.thumb.JPG.03410cdb013adc2f7920b
Brass wire is supplied for all manner of things, such as the random-looking electrical cables that run along the outside walls.
DSC00014.thumb.JPG.3fa7f64301ed470348cd3
OcCre supply no instructions for this kit. Instead, they provide an online build guide which is very comprehensive, showing everything right down to measuring out specific dimensions for everything. This multi-part guide is excellent, with the facility to be able to download each part as a PDF. To check out the guide, head to this link: http://www.occremania.com/diorama-de-istanbul-parte-8-2/
Conclusion
Dioramas aren’t usually my thing, but this looks very tempting, just to see if I can make a reasonable attempt at it and add some airbrush work to make it look a little more lived in. There’s certainly a nice quantity of building material here, and all nicely produced. Recreating the street surface will also be quite absorbing, as well as those kerb stones that are cut from the thick strip timber.
757506782_Screenshot2018-09-28at14_05_31
1619781266_Screenshot2018-09-28at14_04_5
693466152_Screenshot2018-09-28at14_04_42
1028515920_Screenshot2018-09-28at14_04_3
1390903302_Screenshot2018-09-28at14_04_2
My sincere thanks to OcCre for providing the review sample seen here. To purchase directly, click the link at the top of the article.
logo.thumb.jpg.dbe116c7499e14f1650c2a8c8
  • 4 months later...
  • 2 months later...
On 2/7/2019 at 5:01 PM, Pardelhas said:
wow!!! I totally miss it!
And there is a Lisbon tram and diorama as well ;) ...
