kahunaminor Posted July 17, 2019 Posted July 17, 2019 If like me, you like the properties of PPP but struggle with a delivery system and are always on the lookout for modelling hacks, try this. If you know someone in the medical game, or even a friendly chemist, ask for a small syringe (5ml should be fine) and a blunt “drawing” needle. Decant (if that is the correct word) some PPP into the syringe and apply. The needle cap should keep it fresh and you don’t need to fill the syringe, which can be washed in water after use if you wish. Saves wastage and clean up. Regards, 4 1
CrankyCrafstman Posted July 17, 2019 Posted July 17, 2019 38 minutes ago, kahunaminor said: If like me, you like the properties of PPP but struggle with a delivery system and are always on the lookout for modelling hacks, try this. If you know someone in the medical game, or even a friendly chemist, ask for a small syringe (5ml should be fine) and a blunt “drawing” needle. Decant (if that is the correct word) some PPP into the syringe and apply. The needle cap should keep it fresh and you don’t need to fill the syringe, which can be washed in water after use if you wish. Saves wastage and clean up. Regards, Hey Kahuna Deluxe makes a twin syringe kit with different size tips on there web site. I know cause I have it. It works pretty good with the large size tip, the smallest one is good for pva glue. Ron G 4
