crazypoet Posted September 23, 2019 Posted September 23, 2019 I’ve been looking around for a better version of this than what I have. Even with the Eduard PE, the MkII gunsight for the P-47 is just not right, and it’s not a simple fix anyone know of any of these being made? i know they were used on a variety of aircraft and I could likely adapt different versions to fit 1
BlrwestSiR Posted September 24, 2019 Posted September 24, 2019 Barracudacast makes one for the Spitfire. http://barracudacals.com/proddetail.php?prod=BR32011 Or if you think the kit one out of a Tamiya Spitfire is good enough, I can probably dig a couple up for you. Carl 1
crazypoet Posted September 24, 2019 Author Posted September 24, 2019 2 hours ago, BlrwestSiR said: Barracudacast makes one for the Spitfire. http://barracudacals.com/proddetail.php?prod=BR32011 Or if you think the kit one out of a Tamiya Spitfire is good enough, I can probably dig a couple up for you. Carl Thanks! That’s exactly what I needed i’ve not seen the Tamiya Spitfire kit, so I don’t have a reference, but it looks like Barracuda nailed it. It looks like it still relies on some kit parts for the reflector glass on top of the sight body - can I buy one of the sights from you to go along with the Barracuda set? i love the PE mounting frame Eduard did for the P-47 MKII gunsight, but the sight itself is just...wrong 1
