What's the best glue to use with 3-d printed parts? I purchased some 3d printed parts
for a kit I'm working on. These will probably be attached to a painted surface after they
have also been painted.
Paul.
9 minutes ago, BlrwestSiR said:
I used CA on the few 3D printed parts that I've had. You could use epoxy as well but may be messier.
Thanks I'll give both a try.
Paul
12 hours ago, Jeff said:
it's the paint I'm curious about ............... enamels?
No. Tamiya Acrylic paint. The parts I question are headlight quards. I'll
Have to paint the headlights before I put these in place. I suspect I'll have
To use a slow setting glue, and use a brush to touch-up with paint any
Glue that shows afterward. Perhaps I'll use CA gell, epoxy, or the pva  canopy
Glue I've been using. Not sure right now. These parts are ridiculously delicate
and need carefull  positioning. They are the FC Model Trend parts I posted
A while back
Paul, knowing what the parts are, I'd go with the PVA glue. I find the viscosity great for headlight guards as you've only got the tips to put the glue on and it won't run everywhere like a CA might. Plus it has a bit of flex to it when dry in case you bump them.
Only downside is it takes a bit longer to dry.
Thanks, I think that's the best way to go about it.
