Artful69 Posted September 12, 2013 Posted September 12, 2013 Heya ... I know that there's more than one or two issues with Trumpeter Bf109 accuracy ... but by far and away the biggest issue is the rudder. I am told (and have read reviews) that the G-2 builds up into a decent representation - with the main exception of the rudder. Does anyone make an AM replacement? Rog
Dave J Posted September 12, 2013 Posted September 12, 2013 Quickboost does an set for the Hasegawa F which is pretty much the same as a G.. Part number is 32106 Mike (Mikester) has used the set on his Trump kit below 1
Artful69 Posted September 12, 2013 Author Posted September 12, 2013 Quickboost does an set for the Hasegawa F which is pretty much the same as a G.. Part number is 32106 Dave ... You, sir, are a steely-eyed missile man! TYVM!!! ... Ok ... so ... I suppose it's too much to think that the 'F' rudder is the same as the 'E' ??? Rog
Members Mikester Posted September 12, 2013 Members Posted September 12, 2013 Rog, It should fit the "E" as well, although in both cases you'll have to install a little shim on the upper portion of the tail to get the rudder to fit correctly. 1
Artful69 Posted September 12, 2013 Author Posted September 12, 2013 Rog, It should fit the "E" as well, although in both cases you'll have to install a little shim on the upper portion of the tail to get the rudder to fit correctly. Ahhh Thanks Mike! ... Makes sense to me to grab more than one at a time if I can Rog
Matt_ Posted September 18, 2013 Posted September 18, 2013 Both the Eduard and Dragon Es feature separate rudders already and as far as I know are accurate.... I am certainly not 100% but there is a difference between the 109F and 109E tails, whether it is in the rudder or the non movable tail I don't recall... Matt 1
Artful69 Posted September 18, 2013 Author Posted September 18, 2013 Both the Eduard and Dragon Es feature separate rudders already and as far as I know are accurate.... I am certainly not 100% but there is a difference between the 109F and 109E tails, whether it is in the rudder or the non movable tail I don't recall... Matt Well ... I have 3 Cyber-Hobby 'E's already (2 x '4's and 1 x '3') ... plus 3 unbuilt Trumpeter 'E's that I didn't want to go to waste! ... although the G-2 is the next one I'll be building (Trumpeter - hence the rudder correction). I was just curious as to whether the correction would work on the 'E' as well ... I guess I'll order the one set and compare it with the current 'E' components before I buy more. Thanks! Rog
