During the Great War, the Pilot - and the Observer seats were manufactured in the airplanes of all sorts of different materials.
There were seats of braided raffia, wooden seats , simple wooden seat boards - or later -, armored seats from bullet- resistant steel ( Junkers J1 ) or aluminum .
In most cases, the backs from the seats were covered with a thin fabric or leather.
This seat cover in leather or fabric can be shown relative easily with paint or decals.
But there is also another way:
This is the seat of the Hansa Brandenburg W29.
The seat is actually covered with a thin material.
In our case, with simple tinfoil.
First, the paper is cut into the appropriate size .
After, the seat is treated with a very thin plastic cement.
Now, the paper is pressed onto the fresh adhesive.
In contrast to my face - wrinkles are here welcome! ^_^
The tinfoil is bent about 1mm around the edge of the seat .
The tinfoil is cut along the seat back with a sharp scalpel blade.
This edge is fixed with superglue.
Allow to dry.
Now the seat can be painted.
Tamiya dark brown was used as a base color.
Above the orange line that Brown was brightened somewhat , below the blue line was slightly darkened with smoke.
Washing with black-brown Oilcolor.
Then sealed with clear coat.
A extremely thin plastic strip was attached as a seam on the seat cushion.
The buttons were painted with Mr. Color Metal "brass".
Here is the seat of the Pfalz D.IIIa.
This seat cover should look old and a bit worn.
It was used a darker brown than on the seat of the Hansa Brandenburg.
All seats edges was a very light brown color imitated scraped leather.
The seat cushion is not yet final painted in these pictures.
Servus
Bertl
Bertl! Wow!
Thank you so much for sharing these techniques! They really add so much life and individuality to the WnW kits.
Cheers,
Jeroen
BRILLIANT!  I all most certainly use this technique, have tried to come up with a similar solution for a while.  I like yours very much.
