Administrators Clunkmeister Posted September 13, 2022 Administrators Posted September 13, 2022 How? Which filler needs to be eliminated? I understand it’s methanol injection, but where is that tank located? 2
Martinnfb Posted September 13, 2022 Posted September 13, 2022 Tank was located behind the canopy , barrel like, rubber coated. It's presence pushed the battery towards the front of the aeroplane which required a small squared , boxlike addition on the compartment cover plate behind the pilot. MW-50 filling port is on the right side , visible just above the shoulder of the taller guy on the left. Canopy suppose to have an additional pressure gauge, as such. All of the above is visible on this picture ,battery protruding from the sloped backside of the cockpit, MW-50 triangle and filling port And the most fun part is the fact, that in the chaos of the late production of the G-6 variant, all of this and combination of thereof are possible. 3
GazzaS Posted September 13, 2022 Posted September 13, 2022 42 minutes ago, Martinnfb said: Tank was located behind the canopy , barrel like, rubber coated. It's presence pushed the battery towards the front of the aeroplane which required a small squared , boxlike addition on the compartment cover plate behind the pilot. MW-50 filling port is on the right side , visible just above the shoulder of the taller guy on the left. Canopy suppose to have an additional pressure gauge, as such. All of the above is visible on this picture ,battery protruding from the sloped backside of the cockpit, MW-50 triangle and filling port And the most fun part is the fact, that in the chaos of the late production of the G-6 variant, all of this and combination of thereof are possible. Check out this G14 with wide wheel well bulges. Now this would be a worthy subject... if we could see the fuselage sides. 4
