belugawhaleman Posted May 26, 2023 Posted May 26, 2023 As you well know, I like to use the signature function to add literature quotes to my posts.....it's just something I enjoy doing. Lately, I've been unable to do so. When using the paste function, and then pressing save....the quote appears in a larger font than previously, and it has made adding signatures nearly impossible! Why the change? Any attempt to use the size function to change this has not been possible....Why? Paul
ScottsGT Posted May 30, 2023 Posted May 30, 2023 Just spitballing here, but probably because when you did the copy, it also copies the font size and type and it’s imbedded in the info and cannot be changed. I’ve noticed similar things with doing a copy/paste of passwords emailed to me while trying to access pages.
belugawhaleman Posted May 30, 2023 Author Posted May 30, 2023 5 hours ago, ScottsGT said: Just spitballing here, but probably because when you did the copy, it also copies the font size and type and it’s imbedded in the info and cannot be changed. I’ve noticed similar things with doing a copy/paste of passwords emailed to me while trying to access pages. No, tried that.....still comes out huge despite size of source font.
belugawhaleman Posted May 30, 2023 Author Posted May 30, 2023 Tried something different.... It seems to work. 1
belugawhaleman Posted May 30, 2023 Author Posted May 30, 2023 1 hour ago, Martinnfb said: What was the solution? Grape seed oil. Applied with a cotton swab. 1
Martinnfb Posted May 30, 2023 Posted May 30, 2023 It would be beneficial to know in order to identify the root of the problem, in the case this will pop up again.
belugawhaleman Posted May 31, 2023 Author Posted May 31, 2023 3 hours ago, Martinnfb said: It would be beneficial to know in order to identify the root of the problem, in the case this will pop up again. It required , partially, changing the font size used on my kindle fire tablet. The problem hasn't been solved as things pasted from internet sources come out in large font. I have a feeling that this problem is very specific.
Administrators JayDee Posted June 12, 2023 Administrators Posted June 12, 2023 Ok, there's been no change to our system here that would cause such an error. If you paste something into the sig area, the editor will probably carry over any original formatting. A tip to get around that is to paste text into your browser address bar and then copy it again and paste to your sig. That removes all formatting. You can then amend as you like. 1
belugawhaleman Posted June 13, 2023 Author Posted June 13, 2023 7 hours ago, James H said: Ok, there's been no change to our system here that would cause such an error. If you paste something into the sig area, the editor will probably carry over any original formatting. A tip to get around that is to paste text into your browser address bar and then copy it again and paste to your sig. That removes all formatting. You can then amend as you like. Nope. Tried it, doesn't work......a parroted comment? Don't know. I've been doing the same way for at least a couple of years....then, suddenly, the way I've been doing it doesn't work.....Anyway, I found another way. I know the "change" occurred after the site was down. Thanks anyway. Regards; Paul.
Administrators JayDee Posted June 13, 2023 Administrators Posted June 13, 2023 18 hours ago, belugawhaleman said: Nope. Tried it, doesn't work......a parroted comment? Don't know. I've been doing the same way for at least a couple of years....then, suddenly, the way I've been doing it doesn't work.....Anyway, I found another way. I know the "change" occurred after the site was down. Thanks anyway. Regards; Paul. The reason the site was down was due to a power supply outage to the datacenter where we are hosted. There were no actual software changes made to the site.
belugawhaleman Posted June 13, 2023 Author Posted June 13, 2023 6 minutes ago, James H said: The reason the site was down was due to a power supply outage to the datacenter where we are hosted. There were no actual software changes made to the site. I'm just noting that was when I first noticed the problem.
Administrators JayDee Posted June 13, 2023 Administrators Posted June 13, 2023 Have you tried deleting your browser cache and cookies? If you've some corruption stored there, that could affect it. Try another browser to test. I run a site with 42k members which operates the same software and there are no reported issues. 1 1
belugawhaleman Posted June 13, 2023 Author Posted June 13, 2023 1 hour ago, James H said: Have you tried deleting your browser cache and cookies? If you've some corruption stored there, that could affect it. Try another browser to test. I run a site with 42k members which operates the same software and there are no reported issues. Thanks....I'll give it a try. 1
