Hey all
  I'm getting ready to start a new build. It's the Takom 1/16 Panzer III Ausf J that I'm converting into a Ausf N.
I'm kinda in the planning stage, you know figuring out the build sequence I want to use, that kinda stuff. I have a few reference books and pictures. This will be going in a North African, Tunisian diorama along with the Tiger and a Tamiya Kubelwagon.
 Well that's it, I'll be back when I actually get started on the build. Later
Ron G
Hey all
 Ok here's the start of a new project. I have step 1 done. I also modified the return rollers so that they can spin.
20230919_175121.jpgThis is step 1.
20230919_175013.jpgStep 1 done.
20230919_175219.jpgThis view shows the return roller parts, at least some of them. I  added the white plastic rod to the return roller mounting bracket. I drilled out the wheels. The white tube on the bottom left is a kinda poly cap, my version.
20230919_175204.jpgThis view shows the parts assembled.
20230919_175150.jpgThis view shows the outer return roller on the assembly.
20230919_175323.jpgThis view shows all six of the return rollers. I need to paint all of  these before I can attach them to the hull. Well that's it for now be back with more updates soon.
Ron G
Hey guys
  I got some more work done on the Panzer III.
20230920_142109.jpgSteps 2 and  3 done.
20230920_142223.jpgSteps 2 and 3, note the open escape hatches on each side. I drilled out the hinges and added some brass pins.
20230920_180858.jpgSteps 4 and  5 done.
20230920_181029.jpgStep 6 done.
20230920_180700.jpgRight side view of the suspension.
20230920_180644.jpgLeft side view of the suspension.
20230920_130531.jpgThis view shows the modifications I needed to do to convert the turret into an Ausf N. I filled in the hole, no vision port here anymore.
20230920_130549.jpgThis view shows the other side. I have a somewhat front hull interior on order from AFV Modeller so that there will be something in the hull when you open the front hatches.
 Well that's it for now be back soon.
Ron G
Hey all
 Got some more work done on the Panzer III.
20230922_164156.jpgI now have the sprockets and idler wheels installed, I temporarily attached the return rollers for this picture.
20230922_164338.jpgThis view shows some preliminary painting done to facilitate assembly.
20230922_164314.jpgSame thing from the bottom.
20230922_173803.jpgThis view shows a section of the track assembled. Because I modified them with a pin. I can attach the rest of the tracks to either side and the pin will allow for disassembly.
20230922_173852.jpgThis view shows the modifications I did. I drilled out two links so that I could but in a brass pin, this will allow me to attach & remove the tracks once I have them painted & weathered. Well that's it for now be back soon.
Ron G
  On 9/22/2023 at 11:01 PM, CrankyCrafstman said:
Hey all
Ron G
Expand
Good idea on the track pin, Ron. I also have the big Das Werk stug. This
will work on both kits. I was debating putting on the suspension last
when I build these kits....worried about it being damaged from handling.
Pre-painting the back end of the tank also a smart idea.
Hey Paul
  I know that the tiger suspension arms kept me on pins and needles, l would keep hooking them on everything. So far the Panzer III's not to bad. I think I'm probably going to be gluing them in place, they sit way to low, same as the Tiger.🤬
Ron G
Hey all
 Well the interior peices from AFV Modeler showed up today. They took alot of clean up but they look really cool. I'm not going as far as I did with the Tiger, just enough so when you open the front hatches there's something there. The seat on the top left is from a Panzer IV and I'm using it for the radio operators seat.
20230925_154057.jpgThis view shows the parts from AFV Modeler. I forgot to take pictures of the individual parts. Soory.
20230925_153612.jpgThis view shows the parts in the hull. I'm going to scratch up a floor and tunnel for the transmission.
20230925_153645.jpgSame thing from the drivers side.
20230925_153742.jpgThis is a view looking forward from inside the tank.
20230925_153459.jpgThis picture shows the view through the front hatches. Well that's it for now be back soon with more updates.
Ron G
Hey all
  Got some more work done on the Panzer today.
20230927_135423.jpgThis view shows the radios temporarily installed in the hull.
20230927_151226.jpgThis view shows the radios. I took these from my Panzer IV Ausf H I'll replace them when I get back on building it.
20230927_151409.jpgThis view shows the scratch built radio mounting brackets.
20230927_151507.jpgAnother view of the same thing.
20230927_135532.jpgThis view shows the floor plates and the transmitter radio.
20230927_174512.jpgThis view shows the floor plates and the transmission tunnel and modified firewall.
20230927_174411.jpgAnother view of the interior. Well that's it for now be back soon with more updates.
Ron G
Great work Ron. Looking at the hatches, it's hard to believe the crew were expected to enter and exit through them over the transmission housing.
Expand
Hey Carl
 Actually the driver and radio operator entered through the turret hatches. They had to crawl down into there seats.
  There's a video on YouTube by the "Cheften" of the Bovingtons Panzer iii of the 5 different positions in the Panzer iii, have a look it's pretty interesting.
Ron G
Hey all
  Small update for you to look at
20230928_161220.jpgThis view shows the seats in place temporarily. It also shows the reworked pipes that exhaust the heat from the steering brakes.
20230928_161343.jpgThis view shows pipe on the drivers side.
20230928_161558.jpgThis view shows the parts in place temporarily. I still need to make the ammo bin on the radio operators side. I'm just making shapes so when I paint them and you look through the hatches you will be able to see something, instead of an empty hull.
Ron G
Great work, Ron! I was looking at that AFV detail
kit myself.... I see you got the last One! Anyway, they
also got the Ammo rack for the StuG...but I don't
think that would be too hard to scratch build. I'm
glad that your doing this build.... I'm looking forward
to building mine....It's an inspiration thing. Presently, I'm
Hung up on a 1/35 Brummbar right now ...got to do the
cammo then I'm done. Will be watching your build.
Hey all
  More work done on the Panzer III Ausf N. I have the interior painted.
20230930_184209.jpgThis view shows the mostly complete interior.
20230930_184327.jpgSame thing from the other side.
20230930_184421.jpgView looking forward at the drive mechanism. I see there's a spot that I missed while painting. I'll get it tomorrow.
20230930_184525.jpgThis view shows the firewall and ammo bins. On the left behind the radio operators seat mounted to the hull side are the radio transformers.
20230930_184542.jpgThis view shows the hand painted gauges
20230930_184906.jpgThis view shows the two receiver's and the transmitter. I sfill have alot of detail painting to do yet. Well that's it for now be back soon with more updates.
Ron G
Hey all
  Some more work done on the Panzer III Ausf N.
20231002_172540.jpgIt's starting to look like a Panzer III Ausf N.
20231002_172641.jpgThis view shows some detail painting done.
20231002_181138.jpgThis view shows the two receivers mounted to the roof. I still need to paint this area.
20231002_181310.jpgThis view shows the transmitter mounted to the under side of the glacises plate. That's it for now be back soon with more.
Ron G
Some great work there Ron.
I watched the Chieftain video you mentioned and saw how the crew got into the tank. Thanks for the recommendation.
Expand
Hey Carl
  Neat video, but I wouldn't want to be the driver or radio operator if the tank caught on fire...lol
Hey all
  I switched things up the last few days. I decided to paint the three figures that I'm going to use for this tank.
20231004_160604.jpgThis view shows the three figures in there positions in the turret.
20231004_161108.jpgThis is the commander figure.
20231004_161900.jpgThis is a close up of his face.
20231004_161213.jpgThis is the gunner figure.
20231004_162021.jpgThis is a close up of his face
20231004_161405.jpgThis is the loader figure.
20231004_162307.jpgThis is a close up of his face
20231004_161559.jpgThis picture is all three figures. I still have to do a little more blending and coloer modulation to them, plus a coat of flat clear and some washes. Well that's it for now be back soon with more.
Ron G
