Drive sprockets primed. Some of 3D printing lines are visible. These would be very difficult to remove. Most of them will be covered by tracks.
IMG_20241202_115758468.thumb.jpg.c2e4ac0dfcc1597e2d40438553fbaa6c.jpgIMG_20241202_115853539_HDR.thumb.jpg.bcbe7ee45bdb0ab558c180f771a88d98.jpgIMG_20241202_115823038.thumb.jpg.9f2bf33e191673ce98310bd9678ced78.jpg
This kit has been criticised of missing CIP panels. But this kit has one?! Instructions does not call this part at all. So they have rectified this matter...kinda. So now i must fabricate 2 more of these🧐
This chassic is massive 😵. Nice that they have plugged holes of battery compartment and switches allready(there is fine line where those must have been situated).
IMG_20241211_064233843_HDR.thumb.jpg.236eecaaf18e222252955cd8f469e41c.jpgIMG_20241211_064207681_HDR.thumb.jpg.53ef853666cb693bb0a20beb346c1c2b.jpg
Test fitting suspension arms.
3D printed sprocket was perfect fit also☺️. I hope that one extra link is enough per side because this sprocket is bigger than normal.
These wheels look extremely good, FA. Do you plan to weather/tear the rubber tyres? That hull tub looks gigantic. It will take half a bottle of cement to glue it shut :D.
Expand
Thank you Rob🙂. Yes  i am planning to weather tyres. Also get rid off that middle seam.
Just tested that my track length might be spot on.
This kit does not contain any suspension arm attaching srews. You supposed to just glue them in place and hope for the best. Luckily it is very easy to make some spacers and use random srews from tool box. Now i have possibily to fine tune stance if necessary.
IMG_20241214_194727173.thumb.jpg.c7ec87e55f3ecc70e284a669a9d993c9.jpgIMG_20241214_194717233.thumb.jpg.c6e0a73d50d20508b49f473c55d2c2ec.jpgIMG_20241214_194702788_HDR.thumb.jpg.f47492ea021ec04fa9df0f13d4abfe46.jpg
Expand
Is this better?
The lower hull looks great. At least by using screws it should make it a bit easier to level the suspension. Annoying they don't give them to you.
