smitty44 Posted January 12, 2014 Posted January 12, 2014 Hi all! I am looking for a source for the noseweights for the HK B-25 here in the U.S, and I was also wondering if there was a resin barrel for the 50 cals out there I could use instead of the brass ones. I know there is no resin barrel set made for the specific kit but I know there are resin barrels out there. Thanks for your help! John
lawman56 Posted January 13, 2014 Posted January 13, 2014 John, If you look in the review section, you'll see Nigel has recently posted a review of the Eduard Brassin .50 guns for HK's B-17G. Fantastic set, and as they're designed to be placement specific, (turret, waist, tail, etc...), they should work on the B-25 as well. You also might want to try contacting him, as he did an aftermarket review of parts for the B-25 on a different forum. I'm sure he'd be willing to impart some of his knowledge. Hope this helps, and good luck!
Dave J Posted January 13, 2014 Posted January 13, 2014 The nose weights were done by Profimodler.. UMM-USA are the agents in the US http://umm-usa.com/onlinestore/index.php 1
smitty44 Posted January 13, 2014 Author Posted January 13, 2014 On 1/13/2014 at 12:07 AM, Dave J said: The nose weights were done by Profimodler.. UMM-USA are the agents in the US http://umm-usa.com/onlinestore/index.php Ya a quick search shows they carry profimodler products but no sign of the weights...will keep looking,
lawman56 Posted January 13, 2014 Posted January 13, 2014 Smitty, another option would be to contact Ken at Pacific Coast Models. I know they distribute the HK B-25s and have an "upgraded kit" version that includes the nose weight. He may be able to get the weight for you, or point you in the right direction, at least. http://www.pacmodels.com/
Dave J Posted January 13, 2014 Posted January 13, 2014 Is there a reason that you want the weight its self? Why don't you use some fishing weights? I used them in my B-25 and had no issues...
smitty44 Posted January 13, 2014 Author Posted January 13, 2014 On 1/13/2014 at 1:25 AM, Dave J said: Is there a reason that you want the weight its self? Why don't you use some fishing weights? I used them in my B-25 and had no issues... I could as I have lots of them, it just seems like space would better utilized with the cast weight.
Dave J Posted January 13, 2014 Posted January 13, 2014 Thats fair answer... Are you building the Glass Nose?
madelf75 Posted February 7, 2014 Posted February 7, 2014 You can use led shot it will get the job done just haft too fell every open space with it that wont be seen including behind the engines
