This is the older Hasegawa Mk Vb in 1/48 that was issued with Russian markings. The fit is pretty decent as you might expect from Hasegawa, the only issue being some warp in the wing to fuselage fit on one side, requiring me to put some spacers in. Once this is done the fit is almost perfect. Decals however were a little difficult to work with, they silvered on me despite being almost melted into the gloss surface. If I were to build this again I'd go for aftermarket. I did use some colour etch seatbelts from Eduard that really make the cockpit look nice. I knocked up a little base for it to sit on using tile grout for the soil and various grass tufts put into some longer grass mat that was pulled apart a little and then glued onto the surface with white glue. Some accessories were added to the base from the spares box and although I don't have any Russian pilots or ground crew, I will rectify that this week and put them on the base too
  • Like 11
Base and plane are looking very good and the livery is rarely seen on a Spitfire.
I bought a cheap set of Russian pilots and ground crew, the ICM set is actually very nice for less than 20 bucks with 7 figures included. My figure painting is getting better. It definitely adds some realism to the scene.
  • 2 months later...
