I've had this model kicking around the stash for many years and thought while I'm a bit crook with some head cold and currently high on cough medicine, it might be time to start a WW1 aircraft. I don't usually build WW1 so fitting the struts was interesting, I think I managed to get them mostly lined up. I also in my haze, decided rigging would be a good idea. I drilled small holes and threaded some stretchy line through them. It took me a day but it does look nice. A simple little base was made from a wooden thing i found at a good will shop, grout, some spares box stuff, CMK resin pilot and Mini Natur grass tufts. I left the aircraft pretty clean and glossy, I've read that WW1 paints were high gloss and then faded off, but as this aircraft was not in use long I figured a dead flat finish wouldn't be realistic.
The aircraft is apparently one flown by Olivier Freiherr von Beaulieu-Marconnay in probably Jagdstaffel 18, some time in late 1917 or early 1918. He would score 25 victories flying mostly the Fokker DVII between March and October 1918. On October 18th he was hit in the leg, probably by friendly fire. He managed to get back to base but was not expected to survive his wounds. His recommendation for the Blue Max was rushed through, but he would not live to know he'd become the youngest recipient of the award at just 20, dying in hospital 10 days later, only a few hours before confirmation of the award arrived.
A beautiful Albatros you built here, especially in that tiny scale. Congratulations on the result and having the balls to rig in 1/72.
