Hello! After a long absence. This time, I am working on a model of the Fiat G.50 bis ‘Freccia’. I will be using a Fly Models kit (72039) and additional parts in the form of pilot belts from Eduard, an instrument panel from Yahu Models (YMA7253), a Fiat A.74 engine from Yahu Models (YMS7230) and cowlings made by a friend with the designation 368 – 5 on the fuselage. The aircraft will be painted in Furio Lauri's livery, which is not included in the kit, a small change to create a model in a different interesting camouflage.
The fuselage is ready for assembly, Eduard straps are in place, and a Yahu plate has been used. The sight will be mounted after the fuselage is closed.
This is what the Fiat A.74 engine made from the Yahu Models kit looks like before being put together. You can't see it in the photos, but there are pins and holes in the individual engine segments to make it easier to assemble correctly into a whole. A very cool addition is the nameplate, one tiny one for the engine body and a larger one for use on the stand, for example. The second photo shows the motor already assembled. I can't see it on the photo, but there are some notches on the shaft coming out of the engine, in case someone would like to make a ‘Fiat’ with the propeller removed. There are two engines, but there will be several of these Fiats built.
The bottom is ready, now it's time for masking and more colours. I put the white stripe on first.
I masked the bottom and shaded the top, just small jobs, but something got done.
