This marvel has just arrived at the workshop, lying there without its box. So it will be as stress-free as possible to build it. I will present the Curtiss A-12 ‘Shrike’ in 1:48 scale from Czech Model, without extras. The set includes some plastic, some resin and a vacuum-formed cockpit. The model was released years ago, so let's get started.
p?i=0bg16s1
p?i=vagyosf
p?i=cmildpa
Fitting before closing the hull, some minor adjustments were needed, but it's fine.
p?i=lzndi7f
p?i=3ktwo5z
The set includes two wheel options to choose from: injection-moulded and resin with tyre deflection. And here the problem is the same as with the Curtiss A-8, namely that the resin wheels are too large and do not fit in the wheel covers. So the injection-moulded ones were installed.
p?i=u8fwopj
  • 1 month later...
What can I write when the photo shows everything: the glazing is fitted to the fuselage and camouflaged.
?q4goiee
The time has come to assemble the model, and Lego bricks almost always come to my aid. Anticipating comments, yes, the geometry has been preserved in this 6-degree elevation, etc.
?9p5xqyd
