elmarriachi Posted March 9, 2015 Posted March 9, 2015 This little roadster is a resin kit from manufacturer "Industria Mechanica".... and, I think it looks like a small steampunk roadster. The kit is a perfect car for doing some metal works on it.... so the mostyl used colors will be black, silver, alu, steel, brass, gold and copper for it. The first steps.... I cleaned the parts of the frame, the axles and steering, as well as the engine parts and the body. The frame is glued together, putty and sanding made a clear surface. Then it received a black color with the airbrush for the beginning. The engine is also glued together and airbrushed in Iron, before the next parts were painted with the paint brush in further colors (brass, copper and black, as well as different kind of silvers). The body received a first primer in black as base for the next metal works. Next steps: painting of the details at the engine, weathering frame and engine, "metal works" on the body. Cheers Michael 2
elmarriachi Posted March 13, 2015 Author Posted March 13, 2015 After the black primer is dried I stated with Steel color from Rub'n Buff, applied with a cotton stick and polished. Clear coat (glossy) applied before the next steps. With a sponge I added dark grey color partly, then a 2nd layer of clear coat applied. NEXT STEP: The thin frames were paint brushed with copper colour and polished. The dashboard will be painted in black, the displays in white, the frames around the displays in silver and polished. Micro Krystal Klear will be applied on the displays as a kind of glass. The engine was painted in black, copper, brass and silver, then also polished. A black wash was applied for a darker look. Cheers Michael 2
Administrators Fran Posted March 13, 2015 Administrators Posted March 13, 2015 I just love this little model!! And you are doing a fantastic job!
elmarriachi Posted March 19, 2015 Author Posted March 19, 2015 Some new pictures of Her Majesty's Estafette. The body is painted and polished in several layers of silver, the frames painted in bronze and also polished. The engine hood receiveda chipping with a dark blue/grey color. Looking like being painted earlier in grey, now the metal is coming back. The dashboard is painted in black, the displays white with a silver frame. The display it self received some decals which I had on stock. The seat received some seatbelts, coming from the HK Models kit of the B17. The steering wheel and the two levers were painted with oil colors in a wooden look, with some brass details on it. TWo dark brown painted leather bags and a rolled coat (also dark leather) with brass clasps will be added over the engine hood and at the front, two big exhaust pipes in black/silver and an outside mirror follow. Cheers Michael 1
crazypoet Posted March 19, 2015 Posted March 19, 2015 I love this! beautiful job on the steel body in particular
elmarriachi Posted March 26, 2015 Author Posted March 26, 2015 The wheels - made of PE-part and resin - are silver painted and polished, then the tires brush-painted in dark rubber, then the wheels mounted. The bags were painted with oil colors in leather optic. Cheers Michael
elmarriachi Posted April 2, 2015 Author Posted April 2, 2015 The Estafette is mostly finished now, I started with the base for it. On a wooden base I glued the cobblestone part from MiniArt which I cut in the correct size. The wall is also from MiniArt, mounted and glued on the road, then with putty closed some gaps. Next steps - black primer on everything, then painting of the cobblestones in different greys, then finishing the road and painting the wall.... later street lamp and other small parts follow.... Cheers Michael 2
crazypoet Posted April 2, 2015 Posted April 2, 2015 Watching this process just brings a smile to my face - and is an inspiration as well. Beautifully done
Administrators Fran Posted April 3, 2015 Administrators Posted April 3, 2015 This is really a beauty... just love this little model kit! Great work
elmarriachi Posted April 7, 2015 Author Posted April 7, 2015 Thank you very much! And here are some further steps of the base of the little roadster. Now thinking about which color for the street lamp, and what I could add on the wall as details..... (steampunk background...) What do you think? Cheers. Michael
