Washes and flat coat on...
AK 303 on the under/fuselage sides and light grey; A.MIG-1618 Deep Brown on the green; and A.MIG-1617 Blue Black on the underside grey-violet and the control surface hinge lines.
AK 012 smudged about on the undersides.
A very thin 1:1 mix of XF-1 Flat Black and XF-10 Flat Brown was sprayed along the fuselage centreline.
The same mix was used to beef up the exhaust staining.
Some worn-out 1200 grade Wet & Dry sandpaper was then scuffed over the high points in the stain area.
Thanks for looking.  Cheers, Ralph.
"... that'll do time"...
Quickboost's QB 32012 sprayed with Model Master Burnt Steel Buffing Metalizer and washed with Vallejo 70826 German Cam. Medium Brown.
Thanks for following along.  Cheers, Ralph.
Wünderbar!
What a way to finish off the year. Excellent photos too as always Ralph, the white backgrounds really make this particular bird "pop".
Regards,
Dan M
