Members Mikester Posted October 21, 2015 Members Posted October 21, 2015 I'm really getting away from fillers whenever possible and sticking with gap filling CA glue. Sands beautifully, crack resistant and tough as nails. If you're not using it for seam filling and other reasonably small gaps I'd highly recommend you check it out. 2
Members Mikester Posted October 21, 2015 Author Members Posted October 21, 2015 I'm using the Insta-Cure + which is a little thicker than the normal stuff so it kind of sticks in where you put it which is handy. $5.00 for 2 oz. on Amazon, not bad!
Ssasho0 Posted October 22, 2015 Posted October 22, 2015 I'm using Locktide Super Bond liquid glue, its thin and goes into cracks and seam lines by itself. I sand it 15 min after aplucation before it gets fully cured, because after a day it becomes harder than plastic and harder to sand 1
phantomfan Posted October 22, 2015 Posted October 22, 2015 Hello, there is one quite famous, ZAP-A-GAP, probably the first produced for filling purposes, the name is quite evocative too...
mywifehatesmodels Posted October 22, 2015 Posted October 22, 2015 I've used CA for almost everything in assembling plastic and resin models for almost 20 years, now. I use the generic brand that can be found at Walmart (in the US) that comes in the black tubes on a yellow card. It's four tubes to a pack for something like $1.57. Not only are four tubes cheaper than a single tube of some of the big names, but there's usually double the amount of glue in each tube, as well. Also, I haven't had any of the shrinkage issues with it that I have experienced with some of the name brands. Unfortunately, it only comes in a fairly thin liquid form (or probably "medium" compared to some others) and no gel, but I rarely ever need a gel anyway and can usually "span the gap" with a couple/few applications of the liquid, just hitting it with CA accelerator, right away. It also sands very smooth and can be polished to be almost as clear as glass. John
