Welcome,
I started this build when it was first released in 2007/08 and then shelved it for whatever reason. It has languished on my shelf of procrastination since then and when I finished the Defiant, I vowed to do one of the kits that lay languishing. I decided to do this one, as it was amongst the oldest kits there and I felt in a good place to be able to tackle it:
315E8F21-FC69-4777-9C99-21B853DC15AE_zps
Pulling the kit out, I took stock. I had almost completed the construction as the cockpit was finished and installed, the wings were on and the Quickboost engine had been installed into the starboard nacelle:
1E350119-CF58-4BD5-BE80-5DDC7244A665_zps
C094D8AE-6809-434E-B64C-BB5BCCE0670C_zps
8FD679CB-37E5-47AA-B628-688DBC9425C6_zps
EAF351CB-BFC8-415D-92C1-BDE8C218366B_zps
The RLM 02 I had used for the cockpit back then was the Vallejo Air grey/green and it really looked too dark then and still does now but it was staying. I had decided to close the forward gun bay and the nose had been cemented into shape and roughly sanded. The engine nacelles had been attached and the well known gap addressed with filler (I think it was Vallejo acrylic filler) as well as the gaps on the underside wing joins. All in all it looked a bit rough and ready and probably reflected where I was, mindset wise, in 2007. The canopy had been taped over, the gaps taped and the kit put onto the shelf:
492FBE53-0F70-4FB1-A2A3-45BF1A148DB1_zps
BE4EAF29-1426-4B5C-A86C-85C8BFAC44AB_zps
I set about tidying up the seams, removing the steps created by hasty gluing and alignment on the wings and getting rid of all the basic errors. I finished off the MLG bays with the remaining kit pieces, Eduard PE and some styrene. I then completed the lower gear assemblies, fitted the brake lines and shot Aeromaster RLM 02 on all the interior surfaces except the cockpit. It is much lighter than the Vallejo Air and a better representation IMHO:
9FF566A8-25DA-42E3-ACFA-7FACA3E1D089_zps
D9EC5D73-B20F-47DC-967C-6A9F98318E64_zps
CD124EB6-2901-4E08-879A-6D8B2A2D8A12_zps
672F4757-99EA-4540-88E7-EA3876B21ED4_zps
D23D72E1-1645-4171-8DA5-1F5854ADD5BE_zps
The engine nacelles were cleaned up and the lower inlet pieces fitted. The majority of the piece sits on panel lines except the curved section at front which is smooth. So out with the sanding sticks and Mr Surfacer. The exposed engine had a little more detail added with some more piping to go:
6EAAABD0-9C37-47E6-8E03-AA963F9549E7_zps
F2541C55-49A6-4D66-9A49-8FD1003A9687_zps
826BD976-972A-4E63-B331-197DF3DA3B9C_zps
The position lights on each wingtip were removed and the location defined. I will add some CMK position lights later on. The kit wheels are incorrect for a C model, so the Aerocast AM wheels had been partially painted and marked P and S. They have now been masked and the brass details added, awaiting a coat of black:
234EE862-85FF-409D-80DC-3BEAFD8BBD63_zps
1BF18021-FDB6-44A8-914B-563D5D07D1EB_zps
AC0E0BEC-5595-40ED-8599-6D7865C72A40_zps
BD99B5D2-4D85-4782-A443-3110D748CF30_zps
The MG15 was assembled from kit parts, PE, resin and a lot of luck. Naturally after this photo the rear gun sight was flung to the far corners of the earth and a replacement has been sourced. Which allowed me to reverse the front ring side with the rear post as it should be:
3BEDF6B9-AAEA-46F2-A76E-9404052F6F39_zps
The DF antenna is made of two loops but produced as a single part. Judicious use of an RB ultra fine saw and a lot of luck resulted in an equal split down the middle to crate the two rings:
E178506E-5539-499C-9353-7C22CAFFDC12_zps
35CE8868-39B1-4BBF-BAEA-9485DB751002_zps
The rear stabilisers have been added and the whole frame given a general tidy up to bring it to a point where I am almost happy to move on. There is some re-scribing to be done and rivets to be replaced before I commit to paint:
488079DE-3D95-4A94-AD04-51F4F072893A_zps
D4B1968E-B2E5-4164-874E-597A399968D6_zps
I am still to settle on a scheme but I am leaning to the night fighter scheme (L1+DH) from the kit or one of Falck's early birds from the AM Techmod decals. The canopy sections have been dunked in Pledge (Future) and are drying and the PE details for the closed section of the canopy are being assembled.
Thanks for checking in.
Welcome back,
Well there has been a lot going on but not much to show for it. The past couple of weeks has seen me continue to tidy up seams and prepare for painting. I also dipped and masked all the canopies both inside and out:
B80E6EDC-2BD0-4D83-8AC3-4FCB79D5AEBF_zps
8CAEA1AC-1F53-466A-A39B-B74F30015CF6_zps
The PE parts that go underneath the central canopy have been painted and attached. I did this as I intend to attach the central and forward canopy pieces prior to painting, masking the voids with tape. Once the exterior marks come off they will be very noticeable:
82716EAC-2CA2-4012-81D2-C6A9238D212F_zps
EFA307E7-542E-4472-B8B1-1607A222EF28_zps
4B9B031D-6EAB-4DC4-A24F-A3F0DC8AD3DF_zps
I also had a go at filling the void behind the landing light. I inserted the end of a cut off plastic stem from a cotton bud. It gave a nice circular look and then painted the end chrome silver. The cover was then cemented into place. Not entirely happy with the look but at least there is now something behind the glass:
B4612195-FC54-45D1-9872-18A57BDAEC22_zps
At least I have settled upon a scheme:
E29EF0D5-FF00-48F9-870B-AE6AD961BBFB_zps
And with the central and forward canopies on, you can just make out the leather crash pad on the gun sight:
97C26F3B-FFB0-4FE6-8E40-4153B4A9A8F8_zps
16C67FF1-1F1F-43B2-83F9-A63D449AD880_zps
Thanks for looking.
Hello again,
I have been working on a lot of little items, wheels, MG, props and spinners:
53806273-198F-4598-B882-0FA7F39EC6BD_zps
770C2473-6CC4-4264-96F0-11842EE7F3D5_zps
9511D794-6124-4ED4-80BB-F606F6F6979C_zps
1B46F2D2-051A-4CAE-AA8B-61111CB67228_zps
E8CFC922-96B5-4DAF-91E7-BBD674726D2B_zps
32006ABC-77CB-4A28-AC58-B23904016A76_zps
I enjoy these detail work type of items.
Regards,
What I was actually doing was avoiding the final filling, sanding, riveting and scribing. Once I had done the peripheries there was nothing but to dive in head first! Having completed those tasks it was time to mask up and lay the first underside coat of Aeromaster RLM65:
2AFBE44D-B699-40B2-A4AC-0E350CE0B534_zps
2C5CEFC1-33DC-4A20-9870-F43C4B893B80_zps
And with paint on:
962F89E5-1312-4AF2-B4B4-48243D2B50FD_zps
44A98A7E-29AD-4D63-A005-F828359E8D06_zps
7A634DF5-F960-4A35-A1FD-05B5556F7319_zps
F77EC527-79D5-414F-A641-A9CE792C5778_zps
I had a central seam reappear on me so I had to do some remedial work with Tamiya Extra Thin and some clamps on the fuselage sides which fixed the seam. I also missed a seam on the port nacelle. I have a few more touch ups to do such as the rear of the nacelles so I took the opportunity to let it dry before I will retouch the paint shortly:
EFDC4453-A2BE-4C5F-8CF9-BFCC47F47299_zps
Regards,
The undersides were masked in preparation for the first camouflage colour, Aeromaster RLM 70:
E5755D8B-AB06-45CF-8213-6C691B548948_zps
I roughly drew the camouflage pattern on the upper surfaces with pencil and marked the areas to be painted with an 'X'. Once this has dried, I will more carefully mask for the Humbrol RLM71:
BC89E8F3-8D87-46A4-AD47-CF7616AE7E44_zps
7B906C40-66E6-4B3E-BB67-78E55A85F89C_zps
6BA21819-A48E-4FFC-ADD1-45B53CAF1345_zps
F9385554-AA61-45B2-B721-86233AB911B2_zps
CEFEBAF4-7571-45F4-B9D1-A1D101E33290_zps
A9FF4B85-FA3C-461E-BAB9-E3C4771E1727_zps
This is not the scheme I am doing but I use the pattern and mark the areas that will need retouching with RLM 70:
881548BA-F6B4-4D1B-8297-779D36FA442E_zps
Regards,
Bitterly cold so not much work, despite copious amounts of "loft insulation". I have touched up the RLM 70 areas and awaiting the paint to cure before masking. Out of interest, I did conduct a little colour experiment for RLM colours 70 and 71. I used Aeromaster, Modelmaster, and Humbrol enamels. The difference speaks for itself. L to R: H71; AM70; MM70; MM71; AM70; MM70:
630115FA-A791-4F83-AD41-958F22B77E1E_zps
The Aires exhausts got a coat of Gunze Burnt Iron 76:
67FA3D37-F06A-4EA1-9B5E-105DE9253F38_zps
468D594D-C79A-4985-A692-DDE054F23ADA_zps
Thanks Bevan, I appreciate your comments.
To paraphrase one of the long remembered quotes from the iconic TV show "The Brady Bunch", "Masking! Masking! Masking!" Ready for some RLM 71:
0EC7E1E8-B6CE-4136-B7FC-A947DF85FE88_zps
ED87F510-0145-4C36-99BA-5C47669D6885_zps
823FBB7F-234F-4F5A-B80A-E4D9B0A0111B_zps
C5015F71-80A1-42AF-826B-545E082888E9_zps
4EB70735-FB2A-4CF1-A151-166D37DAE3A3_zps
BB8733BE-5E08-4590-AC9B-26BA0807A24F_zps
936DE0E6-E3ED-4C14-8498-39757D8405D4_zps
111EE4B8-4B70-4349-881C-F709430C3833_zps
161EC346-D2E7-48A4-BCFE-C16882C81BEE_zps
Thanks for checking in,
Thanks Ralph,
A pleasant 23C today matey!
Houston, we have camouflage! Not sure why but the RLM 71 dried darker in some areas. Possibly due to the fact I touched up the rear area with a different batch? Who knows, who cares:
118F8A52-D85B-415A-BDEB-97DAE2FF04BF_zps
DFD76094-596B-4F56-8661-F98BA6E152F1_zps
060A6209-6D6C-4566-B6A0-27BEFAA9D902_zps
496BA68B-A0D9-4E18-A19F-E4ECA0C68706_zps
0FF56894-3AC6-40F6-B10F-CDED6CDD87AE_zps
7D74769A-BC80-4102-8988-FCE0FBFA9556_zps
The MLG had pins inserted and holes drilled to add a better strength and alignment. Happy with the end result. Still have a wash to go but I will gloss coat the entire build and then add the washes. Heretic, aren't I?:
718A1FC5-CB05-4BDB-8DD6-76D780080085_zps
1BE606F6-2DC0-4A2C-B51F-7C1836299E42_zps
DE414902-3D74-4674-B6FA-3AAE591159FE_zps
E75BDE8F-5D81-4E85-82CC-7C99AA50F286_zps
The engine still needs some work but after the gloss coat and decals:
FE093915-3EA5-49A0-8004-F7E87A100A5D_zps
AA2343A7-15F5-44AD-9658-75CF8F9E23AF_zps
1C168080-6D96-453B-96C8-9A637848F1BD_zps
Thanks for looking.
Looks like some really great progress! Your engine detail looks great!
Thanks Ralph,
I have made further progress but I am having some Photobucket issues at the moment. Hopefully resolved shortly and I can post some photos!
Regardss
Welcome back,
I had a few issues with Photobucket which have now been resolved. Progress has been consistent with the decaling now complete, the engine detailed and smaller assemblies prepared for final construction. The Techmod decals proved difficult in that they are not inclined to move once placed and are very prone to shattering. I did some research and apparently they need a good pool of water or Microset beneath them and even then they can be unforgiving. I managed to use most of them but some were beyond redemption and the kit decals were used:
48AF591E-7290-4C2A-93FA-D0367C4A5041_zps
B47E3331-4714-4C9F-A300-FBE14EB6754B_zps
A06ADE8F-40D9-4A6A-89BC-23B0B279BCEA_zps
2781F3AD-E0A2-41D4-B78C-714E6A339331_zps
9696D3E2-0509-4DAD-86CC-78D8C0E0A067_zps
More to follow.
Regards,
The QB engine is nice but lacks some plumbing. I have added the most obvious bits out of lead wire and plastic rod:
28355580-E465-4D2F-A9AC-7435ABF158D8_zps
72EE0713-12AF-4E05-BA57-85F93E8EB710_zps
CB5921D5-8653-432A-86C9-390BC947CB29_zps
I am pretty happy with the engine as it stands at the moment.
Regards,
Welcome back,
The wheels are on! You can see the distinctive outward stance of the MLG.
1692900C-A942-4F0A-9148-17FC0FFDE4E4_zps
558C3A29-EA1E-4141-A3F5-E6FF012747A7_zps
I used AK Interactive Landing Gear and Grease and Bearings enamel washes for the first time instead of my usual oil washes. The data plates are from the Aurscale LW cockpit placards decal set:
838C5E26-6702-4D54-BC35-E32A11688DAA_zps
2D2134DC-F9A6-4906-BC2F-19B2565A6A1C_zps
605B494F-7887-4CF9-BB37-8ED0B083F6C6_zps
B99C6EBA-6CD0-4632-91B3-0F0C6B7B8A3C_zps
3B45FAC5-661E-4794-99C8-140D7571F7EE_zps
7AF4BEAA-9E61-4D82-A570-9F3C88D39C83_zps
0BB0C8BA-80D1-4401-8A08-BD31E264751A_zps
Regards,
Hello again,
I shot a couple of thin coats of AK Interactive Ultra Matte Varnish as a topcoat. If you want a dead flat finish, this is the stuff for you. Unfortunately, a number of the decals have silvered. I will chalk this down to a user problem but it means I will probably not use Techmod decals again. The masks came off the canopies and I have a couple of touch ups but I am very happy with the general result. The addition of the mass balances, pitot and a scratch built ladder have finished off the underside:
FD5B7981-9933-4C10-8480-B6025E71A4BB_zps
95021DC7-546D-4B40-B988-00A3A73567D5_zps
4D42536C-D70F-42F3-B562-127B9ADA456B_zps
41A0F06A-8000-4D62-9B4D-09D9E3EBB544_zps
F82CAEF3-481D-425D-966D-6C2A94FCB5F0_zps
EAD1166E-E29D-4902-A46C-18DFA8990A23_zps
F5B014DE-A0FE-4170-9F16-EFEF5A920CA7_zps
2FAD01E9-837A-4AD3-A94B-DE272EF855D5_zps
223E755D-3B65-4E36-BAEC-5EF9EAAE4885_zps
Next up is weathering and final assembly.
Regards,
No matter how many times I tried to convince myself, "silvered decals do not worry me", it was never going to end well. I cut some pre loved Tamiya tape masks for the serials. It appears the silvering is mainly confined to the RLM 71 as the darker RLM 70 is not as noticeable. Maybe something to do with Humbrol paint? Who knows! Not too bad, if I say so myself. The port insignia had also silvered so it had to go. Surprisingly it came away with a new piece of tape (after two coats of matte varnish) and I masked the balkankreutz:
649D1C95-05D4-4A28-A515-4979C174B9B6_zps
20C27715-05EF-4340-900A-0EEBEEC9D5F9_zps
FF372AEE-0018-4FF1-A19B-B06B60E09D96_zps
2D777834-2045-4446-8552-009D44E63ED6_zps
DE0B08C9-C5E4-4E29-BF7F-0D684127D041_zps
That's all for now. I will update you all on the success (or otherwise) shortly.
Regards,
Kent, do you use a clear coat before decals? Solid progress.
Cheers Bevan
Yes matey,
I gloss coated with Pledge before hand. Micro Set and Sol but still they silvered. Mainly the small ones.
Regards,
