Hi all,
After acquiring available drawings and asking a few here and there, I began a looong Spitfire simulator project using basic aircraft fabrication techniques (sheetmetal, riveting, welding, casting). I'll have to make a few concessions, given that it will be a simulator, but will try to keep it as faithful to the original as I can. Some of you might spot something that I did upside down (easy fix :)).
Here's some photos of my progress (2 years now)...
Frame #8 buildup along with intercostal below rudders.
Trim Gauge and Gear Indicator
Youtube video showing trim gauge at work (on a Beaufighter 1c):
Upside down, but an easy fix. :) Machined on a Sherline Mill & Lathe and etched.
Will hope to get into casting next year, but until then, I couldn't wait to get started with the grip and weld some. If I can get it close enough, I might cast it in aluminum later.
Regards,
Zeb
Welcome Zeb, an interesting project you started there. I like the metalwork, you have done, and it's truly large scale.
  • 1 month later...
