Grunhertz Posted October 10, 2018 Posted October 10, 2018 As it says above What's it like as a build? And can someone recommend the best turmbuckles for the same?
Administrators Clunkmeister Posted August 29, 2019 Administrators Posted August 29, 2019 On 10/10/2018 at 4:48 AM, Grunhertz said: As it says above What's it like as a build? And can someone recommend the best turmbuckles for the same? I just saw this and as it’s almost a year old, I’ll just put my thoughts on record. The kit builds up nicely. Bob’s Buckles had a great rigging diagram online, and I encourage you to seek it out. The kit builds like a typical WNW kit. Beautifully. The front and rear halves are built separately then joined after rigging each. If you follow the logical rigging diagrams, you’ll have no issues. Bobs Buckles are great, I use their eyelets in every build. I feel gaspatch 1/32 turnbuckles are often oversized, and I use 1/48 turnbuckles now, especially in control line runs. Manyhere disagree with me on this, but I use Mono line for wing rigging, and EZ Line for control runs. I like the strength given by mono line.
1to1scale Posted August 29, 2019 Posted August 29, 2019 On the other end of the spectrum, you don't have to use either, you can rig a plane using justthe WnW method, just glue ez-line into the holes. Simple and still looks ok. I built my Snipe this way and it looks god on the shelf. I know it won’t win any contests, but I’m happy with it.
Grunhertz Posted August 29, 2019 Author Posted August 29, 2019 Thanks guys I have built it and have the pilots grandson buying it from me I'll dig out some pics later and it is a beautiful build I used a mixture of bobs buckles and radu buckles with prym line 1
