Johann Posted July 2, 2013 Posted July 2, 2013 Good time. I doubt that I write in the right section. If I'm wrong please ispravte. I have a question - will there be interest from colleagues in the Russian aviation WW2?? My colleagues and I are preparing to release a 32 scale (small series) model. If all goes as planned, then - in September will be La-5FN (later will be the La-5 and La-7) in November will be the Yak-1 and Yak-3 (later to be the Yak-1M Yak-7 and Yak-9) yanvore to be ready bomber Db-3/Il-4 If you're interested, I can put you a couple of photos of the process ... 1
nmayhew Posted July 2, 2013 Posted July 2, 2013 Yes! Lavochkins make the most intersting fighter for me I would LOVE a *good* Pe-2 though in 1/32 Yes please do post any pictures / in progress shots etc Many thanks Nick
Johann Posted July 2, 2013 Author Posted July 2, 2013 As they say in Russian - for the seed of the beast Master model fuselage La5FN (Ла5ФН) Master model and a couple of finished parts for quality control Il4/DB3 (Ил4/ДБ3)
nmayhew Posted July 3, 2013 Posted July 3, 2013 the La5 has soooo many colourful options i can't wait to see more the il-4 bomber is a much "braver" choice - for that the choice of medium (injection mould / short run / resin???) may play an even more significant role: personally, i might take a chance on a short run Lavochkin, but probably not on the bomber please do let us have more information as soon as you have - cant wait to see more thanks again Nick
Johann Posted July 3, 2013 Author Posted July 3, 2013 On all models (initially) will be the fuselage and wings of the technology Vacuum molding, and all the other details - plastic low pressure. Unfortunately the equipment that we have now, is not able to shed large-sized form. All models will be equipped with a set of translated mark characters Here for example a couple of interesting options
Johann Posted July 3, 2013 Author Posted July 3, 2013 Well, the work is still in progress Verification is the finishing details on the master layout
nmayhew Posted July 3, 2013 Posted July 3, 2013 Hi Johann thanks for the update (wow that il-4 is big isnt it?!) there are many talented modellers on here who will happily make vacform kits, but sadly I do not have those skills i realise you probably know this, but from a commercial point of view, vacform will really limit your audience or am i misunderstanding you? still, please do keep the news coming, it is certainly an interesting project many thanks again Nick 1
Johann Posted July 3, 2013 Author Posted July 3, 2013 Yes. Certain limitations on Vacuum molding - there is, but ... We have developed such a separation of parts in which the end user will get them already in the form of finished parts for assembly. Ie the end user will not have problems with cutting out parts of the plane Vacuum molding of parts will not differ from the details from plastic low pressure, with the exception of the casting frame To me it is hard to describe, but I will gladly show you the photo after the first model. Many questions will disappear 2
Matt_ Posted July 5, 2013 Posted July 5, 2013 Very interested that you've worked out a method of getting the parts to the modeller without need to remove from carrier sheet. Will that include the transparencies? Those are often the parts that cause the most dread... Look forward to seeing some more progress.. Matt
Johann Posted July 6, 2013 Author Posted July 6, 2013 My colleagues have said - if so requested a sin not to do so. Began to collect materials for the Pe-2. The question is which one to do? (but prepare Budmen after we finish with La and Yak)
Administrators JeroenPeters Posted July 13, 2013 Administrators Posted July 13, 2013 Wow... This is great news. Thnx for sharing this here on LSM!! Curious to see what the end product will look like!
Johann Posted July 13, 2013 Author Posted July 13, 2013 Everything is going according to plan, and therefore - by September will be a pair of test patterns to test assembly and test quality. Looking ahead to say - it will be a full set of cockpit and engine of the resin. Set of etched details. All small items will be casting. Vacuum will be only wings and fuselage Cabin windows will also be casting 1
Administrators JeroenPeters Posted July 15, 2013 Administrators Posted July 15, 2013 That looks great johann! Is that the NEO resin logo in the top right corner?
Johann Posted July 15, 2013 Author Posted July 15, 2013 Not omega (neo) for us makes engines from the resin.
Johann Posted July 21, 2013 Author Posted July 21, 2013 How much would you like to have color options in the set? Whether to make multiple builds (versions) in one set?
imatt88 Posted July 23, 2013 Posted July 23, 2013 Johann, Great stuff! I like both fighters. Keep the info coming! Cheers, Ian
Iain Posted August 14, 2013 Posted August 14, 2013 On 7/14/2013 at 6:34 PM, Johann said: My wife, now with the words - "And I also want something for you to do," began to think about drawing for a boxes )))) Johann, I see that you have used my artwork of the Yak-3 on the box mock-up. I have no objection to you using it but if you intend to use other peoples artwork, you should ask their permission first or you may run into difficulties with copyright. The artist who did the Lavochkin may have other views. Good luck with your project. Iain
nmayhew Posted August 14, 2013 Posted August 14, 2013 other Admin & Mods: I have PM'd Johann regarding this issue 1
Johann Posted August 14, 2013 Author Posted August 14, 2013 1000 apology. The problem of the modern world that the Internet is more freely available and there is no way of knowing whether this is the author's work. Laid out whether the author is realized in free access or is the work of pirates. I assure you that at the arte works of others will not. Once again, I express my deep apology (but now I know whose work it))) As soon as I get out of the hospital, I will show updates on models and present the finished art boxes
nmayhew Posted August 15, 2013 Posted August 15, 2013 Thanks Johann Iain, please PM me if you have any questions / issues... Nick
Johann Posted August 15, 2013 Author Posted August 15, 2013 No, no. No problem. again I apologize for the misunderstanding. Image borrowed from the Yak-3 on the Polish site. Nor any mention of the author unfortunately did not find (old sketches atra removed for ethical reasons. Once again, I apologize to all.
