Signature problem
On 6/12/2022 at 12:10 AM, belugawhaleman said:
Can someone fix/ delete what's appearing at the bottom of my posts? My signature
function is frozen I can't add a new sinature.. I have to turn off signatures otherwise I get
A weird display at the bottom of my posts.
You don't see that in your signature settings screen? Then it's up to the Admins I think.
@Peterpools You have to open the menu under your username in the upper right corner of the screen, chose 'Account Settings' and then on the next screen chose 'Signature' on the left sided menu, to edit yours.
Thanks but the problem is that when I attempt to change my signature there is
An artifact there from a previous attempt to change my signature that I cannot
delete or change. The signature function is frozen  I can only turn off viewing of signatures in order to prevent this showing at the bottom of my posts.
My last idea is, that maybe something is cached there by your browser. I would try to delete cached data and restart the computer and try again.
