A nice, easy OOB build here from Tamiya. I only decal I didn't use was the white fuselage band, which was masked and painted. Camouflage is gunze paints, RLM 80 green, RLM 78 blue and RLM 79 sandy yellow, all done freehand.
7 hours ago, Martinnfb said:
Exceptional airbrush control. :notworthy:
Thank you. Not bad for a 30 dollar Temu special with 5 dollar .2mm tip and needle. I did some lubing and tweaking with brasso to get a better fit between parts which worked nicely. No idea how long it will hold out, but if the tip fails it's only another 5 dollars for a replacement.
Ingenuity and adaptation, I like it. The result definitely speaks volumes. I also found myself gearing towards the so-call nostalgia builds. Not sure for how long, but it feels like those no-pressure/fun builds can help once in a while.
Nice one Brad I take it it's the 1/48 kit?I like crashing some of those easy builds from time to time a feeling of accomplishment :unworthy:
