The Red Baron Posted October 1, 2014 Posted October 1, 2014 Morning all. I frequent a number of sites, and would like to post a few things here, however I have a technical glitsch. Unlike any other site I don't seem to be able to 'paste' anything I've copied, including image links from photobucket. The only way I can get anything to stick is to type it all out, key-by-key, as I'm doing now. Is there some setting or function I'm overlooking?
Ssasho0 Posted October 2, 2014 Posted October 2, 2014 Hi RB, have you tried Ctrl+V? This is how I paste here and no problems so far. Regarding the images, it seems that you have to add them again one by one via the painting button on the bar above the "post reply" field. It seems it doesn't work if you just paste the links with etc. I hope this helps Regards,Sasho
The Red Baron Posted October 2, 2014 Author Posted October 2, 2014 Yep, that doesn't work either. Sub-optimal
wackyracer Posted October 2, 2014 Posted October 2, 2014 OK, maybe this might work. When you go to post click the little switch in the top left corner of the window. This will grey out all the options on the toolbar. This should then allow you to paste links etc into your post. This is how I always do posts with links. Aaron
Umlaufmotor Posted October 2, 2014 Posted October 2, 2014 I have the same problem for month - therefore, I can not post more pictures :-( Servus Bertl
Umlaufmotor Posted October 2, 2014 Posted October 2, 2014 The trick with the switch on the top left seems to be working. Thank's a lot, wackyracer I can write..............but copy pictures is not working. Servus Bertl
Wingco57 Posted October 3, 2014 Posted October 3, 2014 I have problems too since my ipad was updated a few days ago. Cees
RalphSarc Posted October 4, 2014 Posted October 4, 2014 I had problems a few months ago due to the switch in the upper left. Vert frustrating little switch!!
Umlaufmotor Posted October 4, 2014 Posted October 4, 2014 Hurray , it works!! I can finally post pictures again Thanks again for the tip with the switch.
RalphSarc Posted October 4, 2014 Posted October 4, 2014 Hurray , it works!! I can finally post pictures again Thanks again for the tip with the switch. Yay!!!
