So my middle son and I started this the other week, only doing a about 1 hours work prior to him going to bed each night.. Total time spent on it was maybe 6-8 hours at the most.  I did all the cutting, cleaning up and painting, he did all the fitting of the parts.. Its a really quick build and cheap too. I sure that I could of knocked it off in less time if it was only me building it. You really don't need to glue anything in place, but I found that some of the snap fits were to tight and cause hair line cracks on some of the parts. Then adding a enamel wash caused the parts to fall apart.. So if I was to build another one... I would most likely glue everything and see if that would stop it from braking.
So here is the run down on the build...
Chewy and the base of the body.. I wish I added something to scale it next to!
First leg done and fitted to the base -
Cockpit painted.. I used IJN Grey for the interior and Vallejo paints for the switches etc. I used the AK Interactive Grey Wash for Kriegsmarine ships
Everything tested fitted -
Stripped and primed with Mr Sufacer Black
So here are the problem bits that a mentioned prior.. There is a crack on the side dome part and the sensor thingy broke into a few pieces after the wash was applied..
And all painted and done! I will make a base for this another day!
Love these new Bandai Kits.  So much detail in these for 1/48.
Methinks I need to get on to HLJ and get some of these at last :)
J.
Very nice father and son-work. The washing could be a bit stronger on some parts (piping e.g.), but the overall look is great like it is.
Thank you for watering my mouth. Just ordered mine from HLJ.
I have a At-AT from AMT... need to check up the news bandai ones!! :) on HLJ?
