Hi folks,
I'm i need of a good clear gloss coat to spray with my airbrush.
Till now I used a gloss coat from the spray can (Games Workshops' 'Ardcoat) but I need more control using an airbrush this time.
So does anybody use a nice to handle gloss coat?
Preferable an acrylic one.
Thnx in andvance!
Marcel.
Parket Plus or Future is an option. It may need a drop of ammonia to break the surface tension (oppervlaktespanning) so it won't pearl.
I Always liked ModelMaster Metalizer clear coat, although I don't know if that's acrylic or not. Don't know how it goes over the different brands of acrylic.
I had good results with Tamiya or Gunze gloss clear. It does need some retarder or it will dry too fast and give you orange peel finish. I have HEARD (no personal experience) that if you use Tamiya or Gunze gloss clear diluted with Gunze lacqueur thinner it sprays super.
Hope this helps...a bit
I'm swearing by it.... Brilliant!!! For the proper English speakers: the saying goes along the lines that you think something is so good or the like that you'd take an oath on it. In Dutch: To take an oath = "zweren"
            To swear = "vloeken"
Ive always used Future built up in light layers through my Iwata Hp-cs which is all I've ever needed for  proceeding steps of decals and oil washes. The only problem I've ever had with it is a pebble like finish which sometimes occurs on on days of high humidity. Other then that its pretty good stuff, but perhaps not really what your after in terms of a super high gloss finish. Have you ever considered a polishing method ?
Doogs, your method above sounds interesting :huh:  I'll have to try that out at some stage.
Cheers,
Peter.
  • 8 months later...
Hey doogs, hello from Australia, I've encountered probs with glosses& mart gloss as well, but I will try your method for clear Coates in future, my question is what would you recommend for a dull/ Matt final coat? Any advise will be appreciated... Thanks Oz
