Mnemonic Posted June 8, 2016 Posted June 8, 2016 Hello everyone! So the first model I want to build under Diorama GB, will be Dannish Hansa-Brandenburg W.29 in Search & Rescue scheme, as it's seen on 1920 photos. Original photos, found and shared by Ulrich Schnell can be found here: https://www.flickr.com/photos/colesaircraft/galleries/72157624336495042/ It seems that on some photos aircraft appear to be a bit different, with some variations. So after my research on the photos I draw this profile, that I will use to paint my model: 1
Mnemonic Posted June 8, 2016 Author Posted June 8, 2016 I stared with an engine, and decided that I will go with Benz engine, as on the photo above, with left-side exhaust. I made a custom pipe from spare part of Fokker D.VII. Cut it into pieces, glued with some sprue-bits inbetween, then sanded it to be smooth... So far, this is all I have, I started to paint some interior bits... 1
Administrators Fran Posted June 9, 2016 Administrators Posted June 9, 2016 W.29 from Santa Claus!! I'm joking!! Love that scheme. Are You going to inspire yourself in the pic? Fran
Administrators JeroenPeters Posted June 10, 2016 Administrators Posted June 10, 2016 Really cool scheme. I saw Only Bar drew it recently. Watching this one!
Mnemonic Posted June 29, 2016 Author Posted June 29, 2016 Slowly painting and converting some details... Have to finish this step before any assembly start... 3
Administrators Fran Posted July 4, 2016 Administrators Posted July 4, 2016 The propeller looks awesome!!! Those color are quite unusual as you told me on fb... i would love to try some! are only for brush?
Mnemonic Posted July 6, 2016 Author Posted July 6, 2016 Thank you Francisco! I think that they are too thick for airbrushing, they made for a brush. One could dilute it though...
Mnemonic Posted July 6, 2016 Author Posted July 6, 2016 Here is some update on the cockpit workings, everything painted with brush.
Michaelscarborough Posted July 9, 2016 Posted July 9, 2016 This is great! I love the bundles in the rear cockpit and I especially love the color scheme! Like a big peppermint stick! It is so neat to see something different! And, as Fran said, the prop is excellent! Cheers from NYC, Michael
Administrators Fran Posted July 19, 2016 Administrators Posted July 19, 2016 wow!!! If I had two W.29 (I regret myself in selling one of them) I would make the Santa Claus W.29!! Love it! Fran
Mnemonic Posted July 20, 2016 Author Posted July 20, 2016 Got my civilian crowd for diorama! Some of the figures have to be converted to reflect correct time period, but majority will do as is!
Michaelscarborough Posted July 20, 2016 Posted July 20, 2016 That is a great scene, indeed! Neat to see something so different! Cheers from NYC, Michael
Mnemonic Posted July 23, 2016 Author Posted July 23, 2016 And result is here! Stripes are done. Paint will settle a bit more over the next few days. I added "E.I" marking, using thin black permanent marker.
FarEast Posted July 23, 2016 Posted July 23, 2016 Beautiful work Maxim, I always look forward to the updates on this aircraft!
Michaelscarborough Posted July 24, 2016 Posted July 24, 2016 Congratulations, Maxim! BITAREMO!! (Sorry, my computer won't do Cyrillic....) I am most amazed at you ability to keep the spacing accurate! I know it should be easy, using a ruler and tape the correct width, etc. etc., etc, but it never proves so for me. This is coming together nicely! BTW, what sort of paint are you using?? Cheers from NYC, Michael
Mnemonic Posted July 24, 2016 Author Posted July 24, 2016 Thanks guys! On 7/24/2016 at 12:04 AM, Michaelscarborough said: I am most amazed at you ability to keep the spacing accurate! I know it should be easy, using a ruler and tape the correct width, etc. etc., etc, but it never proves so for me. First I drew this scheme in Xara Designer Pro, on top of the blueprint, trying to keep it true to photos (with correct amount of stripes, spacing, angles, etc.) Then, I measured width of the end-result stripe (and spacing, they are equal here), and for 1:32 scale it was exactly 6mm. I was happy to find that Tamiya has exactly 6mm width masking tape, so I bought it. Then it was a matter of time to arrange masks on top of the model, to keep spacing equal I dropped one stripe of mask between of every "real" stripe, then removed it, and proceed to next, end so on... Quote BTW, what sort of paint are you using?? I paint everything using paint-brush, so I use mostly "artistic" acrylic paint. There is one brand that is easily accessible to me in a local shop, called "Deka Lack", this one I use the most, I add some other paints when needed. For example here, for the "white" color I used Vallejo. By the way looking at the photo I noticed that "white" stripes are substantially darker than "white" shirts of the kids around the plane, and you can imagine these are not very clean. So I found one color in "PANZER ACES" series from Vallejo, called "German Winter White", and I used this one.
Mnemonic Posted August 8, 2016 Author Posted August 8, 2016 Small update on Dannish W.29. Painted elevator, finished tail assembly with control wires, finished gun-port fairing, added custom made plexiglas windshield for back seat, added tachometer with a wire, put in place rest of "glass" parts. Also finished all the struts and working on floats now.
Mnemonic Posted August 14, 2016 Author Posted August 14, 2016 Floats are finished and bolted to the fuselage, customized big prop (bigger than usual, as it seems from the photos) is painted as well. Construction is supervised by Porco himself 1
Guest Kagemusha Posted August 16, 2016 Posted August 16, 2016 Wonderful, did you make the prop yourself?
Mnemonic Posted August 16, 2016 Author Posted August 16, 2016 Thank you, after checking photos I realized that prop on reference photos is bigger than any of W.29 options, and has different form. So I choose a prop from WNW "German Accessories", which came with another kit, this prop seemed about right size and about right form. I cut and sanded it a little bit, to make it more symmetrical, to better match photos. Painted it myself, with acrylic paint using brush.
