elmarriachi Posted October 7, 2016 Posted October 7, 2016 Some new project. The British Word War 1 tank Mark "A" Whippet in 1/35 by Meng Models.I have glued it together without any upgrade parts, only some rope on the exhausts.... glued all parts together before painting .... First step - primer in black (Valleyo Black Primer) .... Next I have painted in in a green color from Tamiya, then lightend up every plate at one corner .... then painted every feeled 1000 bolt heads in a ligther green color again. After that I have masked it for painting the white/red stripes. After that I have added some damages with a thin pencil and a sponge, dark grey. The exhaust was painted in rusty color, the guns in Tamiya Dark Metal. The tracks were also painted in Dark Metal, then added a washing in Rust color. Added the tracks to the tanks, then giving the tank several washings in different yellow/brwon/blue/grey/beige/green oil colors before adding dust and dirt with pigments, leaking oil with Tamiya Smoke .... bare metal with a pencil. Cheers Micha
Administrators JeroenPeters Posted October 8, 2016 Administrators Posted October 8, 2016 Nice one! Really cool little tank that you see built often these days. Like the weathering.
Dennis.E Posted December 11, 2016 Posted December 11, 2016 Micha - I would like to put forward a long held theory of mine that the best aircraft modelers either come from a background of building, painting and weathering tanks and/or military hardware, or intersperse the odd tank/military project with their current aircraft projects. I say this because the weathering of tanks teaches one so much with regard to technique, application, color modulation and manipulation, washes and pastel application (including the use of the humble pencil - a technique I have also used in the past)that can be utilized upon aircraft, and take an ordinary model to the next level. Your project is quite beautiful Sir - well done!
