belugawhaleman Posted September 6, 2020 Posted September 6, 2020 Can the extreme metal range of paints from AK interactive be applied with a paint brush or is airbrush only? I want to do some detail work and I haven't used these paints before.They are described as "Airbrush ready" and I'm wondering if they might be too thin for brush work. 1
1to1scale Posted September 6, 2020 Posted September 6, 2020 I tried, but they don’t work for brush. However, you can use Vallejo Metal Color paints with a brush. 2
belugawhaleman Posted September 6, 2020 Author Posted September 6, 2020 Thanks. I'll have a look at the Vallejo paints.
DocRob Posted September 6, 2020 Posted September 6, 2020 I tried too, but without success. For brush painting I use different products, depending the conditions. True Metal waxes from AK, metallic colours from Scale 75 (acrylics), sometimes dilluted Tamiya metallics, and lots of different Pigments, where the Uschi van der Rosten are the best, but only available for steel, chrome and iron tones. Brushing metallics is not so easy, I found, the finer the grain, the better the results. Even different Tamiya Aluminum tones are very different in the outcome. I try to airbrush metallics as much as possible and here are the AK Extreme Metals my go to, great shine, fine grain and very durable and especially durability wise, they are better than most of the Alclads. Cheers Rob 2
belugawhaleman Posted September 6, 2020 Author Posted September 6, 2020 Thanks, I'm looking for a metallic paint that looks like tarnished brass that I can brush. I was thinking I might try mixing acrylic paints like tamiya, or perhaps enamel paint to achieve this effect. Any Ideas ?
DocRob Posted September 6, 2020 Posted September 6, 2020 I don't know what you have in mind, but I had a recent project, which involved a lot of non-FE finishes, that might help. Most of it was sprayed, but I used lots of pigments an pastes and hand painting to get the project done. Cheers Rob
belugawhaleman Posted September 7, 2020 Author Posted September 7, 2020 Rob, your Nautilus and Squid looks fantastic. I'm just looking for a more realistic weathered looking brass or copper finish than the too bright looking brass and copper paints I've been using. I'm planning another Takom Renault ft build and I want the engine to be a little more realistic this Time. 1
DocRob Posted September 7, 2020 Posted September 7, 2020 When I paint metals, I start with a new looking finish of colour or wax on primer and try to achieve the most realistic looking metallic sheen. Then there is weathering and ageing the metal. With copper and brass, everything is about patina, which can be best achieved with blue and green washes and mainly pigments. A good guide for copper ageing is made by the talented builder Fichtenfoo. http://fichtenfoo.net/blog/in-progress-»-fish-sub-»-copper-patina-»/ I hope that helps, as a Renault FT is as close to steam punk as possible . Cheers Rob 1
belugawhaleman Posted September 8, 2020 Author Posted September 8, 2020 Thanks for the link. Interesting article and wonderful patina effects. 1
