30 minutes ago, Old Dog said:
Nicely done as usual :thumbsup2::thumbsup2:. Did you go with straight flat black on the underside ?
Thanks! I used a semi-gloss "scale black" that I mixed using MM Flat Black, MM Gloss Black and some MM Flat White. Using the white gives it more of a scale look than just dead black. When finished I oversprayed the whole model with Alclad Clear Flat. I usually use a mix I call "flat scale black" on various things like radios, tires, etc. :)
4 hours ago, Jackster said:
Brilliant job John, well worth the effort to push it over the finish line!
Kev
Thanks Kev. I'm glad you like it. :)
