1:32 Junkers Ju 88A-4 with bombs
Revell
Catalogue # 03988
Has it really been SIX years since Revell released their much-lauded 1:32 Ju 88A-1? I really don't know where time goes. What perhaps isn't too forgivable, giving that time span, is the length of time it's taken Revell to finally launch the A-4 boxing of this kit. The A-1 parts break down did pretty much indicate that we would indeed see other variants of this iconic aircraft, but why so long to deliver? Never mind, for me, I'm just pleased to say that we finally have this kit here on our desk for inspection. Revell, you are forgiven.
If you've seen the previous A-1 boxing of this kit, you won't be surprised to know that the A-4 occupies the same size packaging, this time adorned with superb artwork. Inside that slightly flimsy top-opening box, THIRTEEN sprues of light grayish-blue styrene, and TWO sprues of clear plastic are supplied. With the exception of the clear sprues which are packaged individually, the remaining sprues are packed in a combination of separate packets, with a number of them doubled up – notably those for which sprue multiples are supplied.
This kit isn't simply a reworked A-1 with a handful of different parts. Yes, there are a good number of parts which are indeed common to the previous release, but not all. Some sprues have been replaced with newly-tooled ones which are specific to the A-4, whilst we also have new parts which weren't included in the first release, namely a set of external bombs and ETC racks. This is the summary of changes/inclusions in this the Ju 88A-4 kit.
  • SEVEN sprues common to Ju 88A-1 kit, including new radio set part on sprue C, omitted in A-1 kit
  • FIVE newly tooled sprues, specific to this release
  • TWO sprues deleted from A-1 variant.
So, in total, more plastic included in this release. Let's take a fresh, new look at this release in more detail. You'll notice a break in the sprue lettering sequence due to deleted sprues and newly included ones.
SPRUE A
Being the first, common sprue to the previous A-1, you'll not be surprised to see this one carries key airframe components for this build, namely the fuselage halves and wing upper and lower panels. The beautifully detailed exterior surfaces to both wings and fuselage contain some very refined panel lining and port access detail. As is common with Revell design, there are no rivets to be found anywhere. A few fasteners here and there, yes, but apart from that, the surfaces are a blank canvas for those who perhaps want to add these themselves. I'd much rather add rivets than want to remove excessive divots seen on some kits.
All moulding is exceptional, with no defects, next to no flash anywhere, and no trouble with ejector pin marks in the cockpit area due to the interior walls being separate parts. The spine and lower forward fuselage are provided, as before, as separate parts. Slots in the wing roots exist for the interior formers with their integral wing spars to pass through.
SPRUE C
Here we find more parts which are common to the previous release, namely the two internal formers with their integral wing spars, rear engine nacelle sections, where there bisect the wing leading edge, and also the large rear nacelle underside section, with the gear doors moulded in situ in a closed position. For the tail area, we have two more spars which insert within the rear fuselage, and give a positive locating point for the large horizontal tail surfaces. There are also the two tail root fairings included here.
The interior walls for the cockpit are included on this sprue, but will be fitted out slightly different for the A-4 version. These are superbly moulded, with plenty of sharp detail, and look great when painted and assembled. Lastly, a new part for the upper radio bank panel is included. This was snipped off from the previous A-1 release so as not to confuse it with a similar part which was included on the deleted sprue B.
SPRUE D
Another common sprue. The Ju 88A-4's horizontal tail surfaces were common to its earlier incarnation, and you'll find them moulded here, complete with their separate elevators. The remainder of this sprue is given over to the rather chunky undercarriage legs with moulded gaiter, undercarriage support structures and also dive brakes. Going back to the undercarriage legs, these are moulded as halves, which for me, was always a weakness in their design when it comes to supporting a large and heavy model. Still, this does at least allow you to add a steel pin within them in order to make them a little more rigid.You'll notice just how warped this sprue is. Nothing in the packaging seemed to have caused this, so I can only assume the sprue was perhaps too soft when being handled from the mould.
SPRUE F (x2)
This sprue contains a mish-mash of parts, from the two part, un-weighted wheels, and numerous other parts associated with the u/c, such as scissor forks and hydraulic rams, to the aileron horns and sealing strips which allowed unbroken airflow when aileron angle was changed. My experience of the earlier version showed that these need to be trimmed to their correct length before installation.
SPRUE G
Revell have spilt the ailerons over two sprues, with the upper halves being included here. The common cockpit parts, such as internal canopy 'roll frame', radio wall, etc are superbly moulded, with fine, sharp detail. Here, you will also find the lower, forward fuselage section, the exterior panel to the front of the windscreen, as well as numerous parts concerning assembly of the tail wheel fork.
SPRUE H
This is the last of the regular, common sprues, and again contains a variety of parts from a number of airframe areas. Apart from the lower aileron halves that I mentioned were separate to those parts on sprue G, included here are the gondola shell itself, cockpit floor, consoles and seat/seat frames etc, fuel dump parts, and a series of formers which install into the tail wheel bay. Just as an aside, if you are a super-detailer, then there is an upgrade pack from Profimodeller which replaces the tail wheel bay parts with a completely detailed interior. See our review here.
SPRUE I
Although this clear sprue is common to the A-1 variant, the instructions rightly shadow out the use of the rear facing canopy part, with it's single MG installation point. Also not for use are the round window panes through which the MG would fit, despite there being two moulded. They are not the correct pattern for the A-4. The gondola rear MG glazing is also redundant.
Parts which can be used of course, are the forward canopy, side window panels, and lower forward glazing, and the glass nose. Other parts here are for the bomb aimer position, and forward gondola etc. All glazings are beautifully clear and frame lines have sharp edges, unlike those of the later He 111 kit.
SPRUE J
We nip over to a newly tooled sprue now, in its light grey/blue plastic, matching the rest of the kit. Now perhaps you can get an idea as to why Revell engineered this model with a separate spine and wingtips. The A-4 variant had a span which was around 5 feet longer than the A-1, and those extended wingtips, and the resultant lengthened ailerons are moulded here.
Not only where the wings slightly different, but so was the vertical fin. As well as being a slightly different shape, the rudder also had a tab which notched into the fin at the top of the section. All parts are included on this newly tooled sprue.
Now what about that spine? The A-4 spine is slightly different too, housing the Funkgerät‎ dipole aerial and the clear cover which sits atop it. Some panel lining is different too, indicating a slight change in the position of the dinghy stowage position.
The remainder of the parts on this sprue concern the cockpit of the A-4, and its different 'fitting out', including new ammunition boxes and MGs, and an entirely new instrument panel which also differed to the previous release. The panel is excellent, and individual decals are supplied for the instruments.
SPRUE K
This newly tooled sprue contains the external ETC bomb racks and swing braces. Prior to this release, you had to pay for such parts from AM companies, but now, you can save yourself a few £/$/€. The racks also don't disappoint, being detailed enough for most modellers.
SPRUE L (x2)
The A-4 variant called for a new cowling, and these are supplied over two new Sprue L additions. These have been designed so the channel section which sits below the cowl, is a separate part, so no seam to remove here. There are also newly shaped prop blades, new exhausts, spinners and hubs too. Revell have chosen to add the undercarriage doors to this sprue too, as they did on the equivalent, deleted sprue E
SPRUE M (x2)
Bomb racks need bombs, of course. Revell have provided two 50lb bombs and two 100lb bombes for this purpose. Moulded as halves, with separate tail fins and fin strengthening rings. There will of course be seams to remove on those bomb cases, but that's pretty unavoidable.
SPRUE N
Now we have the very last of our sprues, and again, another new one. Containing seven clear parts, this covers the new 'bug-eye' rear facing canopy, with its twin MG installation, and also the dipole cover, rear gondola glazing, and also an internal forward canopy-mounted gun sight. This sprue was cracked in my review sample, but Revell quickly rushed another one out to me for this article. Great service!
Again, all parts are superbly clear, and frame definition is excellent.
Plastic summary
There are a few traces of flash on some parts, but nothing really out of what you would expect from most mainstream injection moulded kits. The kit is free from any troublesome sink marks, and ejector pin marks are thoughtfully placed. A few seams will need to be removed, but certainly nothing out of the ordinary.
INSTRUCTIONS
You either like Revell instructions, or hate them. Oddly enough, I quite like them. They're fairly retro and remind me of my misspent youth. They almost look like drawn images, and not the usual CAD-rendered sort we commonly see today. The paper they are printed on is not the best grade either. For me, I find them easy enough to follow, and they also show colour call-outs for the various parts and assemblies.
This booklet has 18 A4 pages, and there are 113 constructional stages, with two more stages given for the two schemes supplied with this release.
DECALS
A single, large sheet, printed by Cartograf, is included. Printing is exactly what we have come to expect from this manufacturer, with nice thin decals, minimal carrier film, and perfect registration. Colours aren't too vivid either, so no need to tone things down. As Revell is a German company, no swastikas are included, so you'll need to source your own. A tail band is included for one version, but I would mask and spray this as you're sure to get a more pleasing result.
A full set of stencils is included, as well as those cockpit instrument decals etc.
Two schemes are included, and these are:
  • Ju 88A-4, 4./KG54, Catania, Sicily, April 1943
  • Ju 88A-4, 3./Kü.Fl.Gr 506, Leeuwarden, Netherlands, April 1942
Conclusion
A lot of modellers have been waiting for this version for a long time. Of course, there have been conversions for the earlier A-1 release, but that does indeed cost extra, and in this day and age, perhaps an extra expense that some modellers can ill afford. Revell have produced a superb kit, with those new parts being every bit as good as those from the original release from 2008. You now have a world of new schemes at your fingertips too, with decal releases from the likes of Eagle Editions.
Thankfully, Revell have chosen not to mould seatbelts on the parts in this release, as they did with the He 111 and Bf 109G kits. Their belt renditions are bloody awful, to be honest. If you want belts for this set, consider the textile sets now available from both HGW and Eduard. In all, this is a superb release!
Very highly recommended
James H
Our sincere thanks to Revell for the review sample. Revell model kits are available from all good toy and model retailers. For further information visit www.revell.eu
Great stuff James
I still haven't bought one of these... it does look good and as you say, the bomb racks are excellent for injection moulded items. I wonder why the big gaps on the bomb rack sprue...?
Matt
It's a great kit
Bomb racks are significantly better than their He111 counterparts, but I would still recommend using resin ones - I have the MDC selection and they are very good
Totally agree that its a great kit! Very temping to get another one for the stash... but I think 4 88's are over kill!
Great review!!! I don`t have any Revell 1:32 but this will be on my stash.
Francisco
I must agree with all of the foregoing comments James, a spot on review!! I really enjoy your comprehensive approach to reviews and they truly assist me in making retail purchase decisions!
Is it me or is it just a quirk of timing that you've recently reviewed two of the best twin engine medium bombers of WWII?Just like buses, you wait a good while and two come along together!!
Best regards,
Steve S.
Beautiful kit. I realy love the Revell Ju-88 family...............................
...................................but I would rather save my money on the Wingnut Wings AEG G.IV - Bomber.
@Dave J  -- when you said this AEG-kit is to have? :ph34r:
Servus
Bomber
  • 2 months later...
Just found this fantastic review on the kit I just bought. Great review Jim and thank you for all the interesting details!!! I was completely enlightened to all the features in this new Revell offering. My skill set has improved since building the older 1:32 Ju 88A-1 kit so I look forward to using those new skills on this kit for the GB.
Thanks again for this informative review.
Ralph.
