Nieuport Posted October 30, 2013 Posted October 30, 2013 Hello, I will start here my build of the new Renault FT kit in 1/16 from Takom. I usually build in 1/72 or 1/700, so it will be a different build for me Eric 1
Administrators JayDee Posted October 30, 2013 Administrators Posted October 30, 2013 Same here....I can take your lead on things
One-Oh-Four Posted October 30, 2013 Posted October 30, 2013 Great! Don't let the square metres of plastic you'll have to paint intimidate you! I'm still unsure which one I want to build: Takom's 1/16th or Meng's 1/35th...
Nieuport Posted November 1, 2013 Author Posted November 1, 2013 Hello, Here are my first pictures. I started with the engine but I still need more information about colours. According to someone in the tank museum of Saumur, it was completely painted in black except some element in copper. I will have a picture today. I don't like the "all black" option. As I saw some pictures with different colours, I will continue to search. The parts fit well together, however some filling and sanding are required. To be continued ... Eric 1
Jamme Posted November 1, 2013 Posted November 1, 2013 Nice start on this one! One question, can't you put bigger pics? (At my age eyes are not so good anymore..... ) Congrats, Jamme
Nieuport Posted November 1, 2013 Author Posted November 1, 2013 Hello, Thank you for your comment. If you click on the pictures, you will have larger one. I don't know if it is better to have directly big pictures or miniatures with link to big pictures. Eric
Nieuport Posted November 2, 2013 Author Posted November 2, 2013 Hello, As I still waiting for more information of the colour of the engine, I switched to the tracks assembly. There are 3 parts per link and 32 links per track !!! And on the wheel : At the moment, 17 links are glued together, still some work to do Eric 1
Nieuport Posted November 10, 2013 Author Posted November 10, 2013 (edited) Hello, An other update, the engine looks more to an engine, now. Some parts are not glued yet to keep the painting process easier. The gearbox : And just for fun, a fitting test of the engine and transmission : The adjustment of the parts is not at the Tamiya level but are good anyway. Some filling/sanding is necessary. Eric Edited November 10, 2013 by James H removed the URL tags and replaced with [IMG} tags
Administrators JayDee Posted November 10, 2013 Administrators Posted November 10, 2013 Hi Eric, That's looking great. Those seams were a little difficult to entirely remove eh? I know they were for me. When you add the image to the post, use the direct image link in your image site, and post into the image button in your editor. An easier way is to use the IMG image links if your host generates them, then just paste into your post. an example is this: [IMG]http://i57.servimg.com/u/f57/11/95/78/34/ft_gir18.jpg[/IMG]
Nieuport Posted November 10, 2013 Author Posted November 10, 2013 Hi James, If it is allowed, I will post my pictures directly in large size, it is easier. Eric 1
Administrators JayDee Posted November 10, 2013 Administrators Posted November 10, 2013 Hi James, If it is allowed, I will post my pictures directly in large size, it is easier. Eric Cheers Eric, I'm enjoying seeing you build this. I'm a plagiarist, so updates are always welcome
Nieuport Posted November 11, 2013 Author Posted November 11, 2013 Hello, I finally sprayed a coat of primer on the parts, this allow to see better the imperfections ... and the parts It is not easy to work with this red plastic. And some parts in place, just to see : To be continued ... Eric 2
Administrators JayDee Posted November 17, 2013 Administrators Posted November 17, 2013 I know what you mean about the plastic colour. While some say colour doesn't matter, the colour and qualities of it make it difficult to see if you've removed seams and sprue gate points. Even when you shave away tags, there is still a shadow exists that makes things difficult to gauge. Still, I think it's a wonderful kit that fits real well. You're doing a great job with this and real trailblazing things for my own build. All I can say is 'thank you'
Nieuport Posted November 20, 2013 Author Posted November 20, 2013 Hello, Thank you for your kind comments.Now, I will present you the first real issue of this kit. It is the position of the rod which maintain the 2 caterpillar assembly (I hope that everybody will understand what I want to explain).1st picture : the part fitted on the floor : Then a test with the side of the body. It cannot be placed in good position, the rod is about 1mm too low : So, I filled in the floor with plastic card : And then, glued the rod in place. The assembly is weaker but the fitting is possible : That proves (if it was still necessary) that the fitting test is always necessary. I also finished one of the track assembly. Next step, beginning of the engine painting. Eric
One-Oh-Four Posted November 20, 2013 Posted November 20, 2013 Great progress, Eric! I'm looking forward how the rest turns out! Cheers!
Nieuport Posted December 8, 2013 Author Posted December 8, 2013 Hello, I spent some time to study pictures and various documentation to continue my FT, and I progressed a little bit on the engine.Painting the exhaust collector : Then : and : To obtain that :I am not completely satisfied with the rendition because of the aluminium paint used (Alclad 101 aluminium). It is too bright and I will tone down it. I will also repaint the other parts already painted with Alclad 117 dull aluminium, that should be better. The engine will receive a wash of dark brown and then some dry brush with lighter colours. I also spent some time to find some springs to replace the fake ones provided for the tracks. I also bought some brass square tube to rebuild the suspension : Maybe an other update this evening, Eric 1
Nieuport Posted December 8, 2013 Author Posted December 8, 2013 Hello, Today, I had time to do some paint in Alclad Dull aluminium : The motor needs some weathering : Eric
Ssasho0 Posted December 8, 2013 Posted December 8, 2013 Hi Eric, its looking excellent! I will keep my on it as I have the 1:32 version from Meng Best regards, Sasho
Administrators Fran Posted December 11, 2013 Administrators Posted December 11, 2013 Nice work!!! Very nice!! Will follow! One thing I do not understand is the plastic color..Odd color that Takom choose.... I really don`t like it...
Matt_ Posted December 11, 2013 Posted December 11, 2013 Lovely work on this beasty... Just a quick question... when you have the engine compartment laid out in the early photos, I can't see any connection between the engine and the transmission... Is there another part to go in? Matt
Nieuport Posted December 11, 2013 Author Posted December 11, 2013 Hello, Thank you for your kind comments. Matt, between the engine and the gearbox, there is a big pulley which drives the cooling fan of the radiator. I was not able to add it as it requires to be attached to the side of the tank. I just sprayed a coat of mat varnish on the engine. There will be an update at least this weekend. Eric
Nieuport Posted December 16, 2013 Author Posted December 16, 2013 Hello, A little update, I started the weathering of the engine and continued to prepare some various elements. I finally understood how the accelerator is connected to the motor, I understood also what is the utility of the tank on top of the engine, it is an auxilliary gas tank with a return hose to the main tank. I am still looking for information to know how the gas hose is connected to the engine (the path of this hose). and I prepared a hose to guide the spark plugs wires from spark plugs to ignition system : Eric
