Since the 190A-7/8 build has crashed and burned I plan to build a companion kit, the 190D-9. Most of the parts are interchangeable so I haven't lost a good bit of the work done on the A. This is the one I plan on doing. A very good reference and I have the decals and paint colors on hand. :)
Some updated info on the color scheme. Also, this is a Revell kit which uses the Hasegawa molds. :)
  • JohnB changed the title to Revell FW-190D-9 Brown 18
54 minutes ago, Peterpools said:
John
Nice choice of subject and you certainly did your homework. Going to be a terrific build and will be in my front row seat. :popcorn:
I feel like it will be a nice looking model Peter. I like that "Brown 18". :)
Got a good start on this one. I used the cockpit set that was on the A-7 as it was all done and fit just fine etc. Might be a little inaccurate for a D-9 but I DON'T CARE! :)
37 minutes ago, KevinM said:
I hear ya John be of the same attitude myself.;)
36 minutes ago, Peterpools said:
John
Looks great and right with you and Kev
Thanks Peter. :)
Looking seamless John is this a re-boxing by Revell or of their own production.I understand my Me-110 is a re-boxing of Dragons so I order the Dragon Quintas kit waiting for it to show up.;)
Yes, it's a re-boxing of the Hasegawa kit.:)
  • JohnB changed the title to Revell FW-190D-9 Black 10
I've decided to change subjects. Since I built a D-9 in 2013 of the same unit (JG 26) with similar markings I think I'll do this a/c instead. Same unit but different markings, etc. Those are original Luftwaffe boots. I have another pair I'd sell. PM me if interested.
4 hours ago, Bomber_County said:
Been awhile since I’ve seen a big Dora, do you rate Hasegawa 32nd, never built any?
Hasegawa 1/32 kits are very nice with great detail. Fit is, for the most part, very good. Recommended. :)
At the painting stage! As some of you know RLM 84 has several variations of which I have posted three versions.  I chose to use the #3 version of the paint "chips" which is a old AeroMaster color. RLM 75 also has more than one version. For the under wings I chose to use version #1 from the paint "chips" which is White Ensign. For the upper wings I used version #2 which is another old AeroMaster color. I'll post a photo of the top sides when I've finished painting them.
John
Brilliant work and your research on colors is amazing. I'm happy to realize model paint companies have numerous interpretations of the RLM colors I'm using on my 109.
Are the color variations you are using due to model paint companies or what was done during the war as supplies of paint colors must have been hard to come by.
30 minutes ago, Peterpools said:
John
Thanks Peter.
It's some of both. During the war paint suppliers had different interpretations of what certain colors should look like plus there might be several different suppliers. It also depended on what they had available to work with. And there would be several different "companies" supplying a/c components which would lead to even more diversity, etc. About the same rule applies to model paint makers today although I don't think the supplies are as difficult to come by plus references are much more available, etc. :)
John
Sounds correct as paint seem to be one of those 'parts' that are open to a wide interpretation by manufacturers. And then throw in shortages as the war progressed and just getting close must have become good enough.
Camo painting done. Next will be a overall clear gloss in preparation for decaling. :) That light green RLM 82 sure looks unusual but will be fine after decaling, etc is done. (There is some confusion in references as to what is RLM 82 and what is RLM 83. Some say 82 is dark green while some say it's the light green. Same goes for the RLM 83. Go figure. I just go by photos and/or good artwork and make my own decision as to what's what, etc.)
37 minutes ago, Peterpools said:
John
Paint work looks smooth as can be. Looking so good.
Thank you Peter. I'm looking forward to applying the decals as I think they will really set it off nicely. :)
