FullArmor Posted September 12, 2023 Posted September 12, 2023 Hobbyboss 1/35 Started with wheels. 6 1
Martinnfb Posted September 12, 2023 Posted September 12, 2023 Nice choice, I’ll follow with interest. And welcome to the forum:) Cheers Martin 1
FullArmor Posted September 12, 2023 Author Posted September 12, 2023 Thank you. Just realised how hard this plastic is compared to Tamiya. 2
PanzerWomble Posted September 12, 2023 Posted September 12, 2023 The opportunity to weather something to death I've found Hobby boss stuff generally has a decent fit , so hopefully so with your build . 3
FullArmor Posted September 12, 2023 Author Posted September 12, 2023 "The opportunity to weather something to death" True. That was the idea. To learn and try different techniques. Also i like angular surfaces. 3
FullArmor Posted September 16, 2023 Author Posted September 16, 2023 Suspension units done. Here is my basic tools which i use to remove spruemarkings. I do not use metalfile. Sandingsticks are made of stirringsticks and sandingpaper glued together. Then i remove sanding marks with scotch brite. What are your basic tools? 3 1
FullArmor Posted September 20, 2023 Author Posted September 20, 2023 Lower hull almost done. I am impressed level of detail this kit has. 6 1
PanzerWomble Posted September 20, 2023 Posted September 20, 2023 Curious , the AFV club Centurion provides a real metal spring for the suspension units, I see Hobbyboss doesn't. TBH it's makes little difference on the AFV club one other than a very limited movement. Tamiya's old MK3 clunker had it all as one moulded lump . Are you using the plastic individual tracks or going metal ? Personally find the metal tracks a lot easier to work with than glueing single links together. +1 for Scotchbright - absolutely great for removing the odd glue fingerprint as well I find 😀 1 1
FullArmor Posted September 21, 2023 Author Posted September 21, 2023 I would like to have metal tracks. Or workable tracks made of plastic. Any recommendations? 1
FullArmor Posted September 22, 2023 Author Posted September 22, 2023 Upper and lower hull fitting. Made few mistakes. Hopefully addon armor fill cover gaps :) 3 1
PanzerWomble Posted September 22, 2023 Posted September 22, 2023 On 9/21/2023 at 4:45 AM, FullArmor said: I would like to have metal tracks. Or workable tracks made of plastic. Any recommendations? I tend towards Fruilmodel from CZ though they announced this summer they are shutting down . You can still find their stuff on eBay eg Just an example 1
FullArmor Posted September 23, 2023 Author Posted September 23, 2023 Just realized that my drive sprockets dont fit tracks. There is about 1 mm gap needed between sprockethalves 3 1
PanzerWomble Posted September 23, 2023 Posted September 23, 2023 Thats poor of Hobby boss - you can shim it perhaps ? 2
PanzerWomble Posted September 23, 2023 Posted September 23, 2023 Or cut off the individual teeth on the inner sprocket where they are covered by the track so it fits and you don't see misfit . Done that trick before ! 1
FullArmor Posted September 23, 2023 Author Posted September 23, 2023 1 mm shim needed for future Nagmachon buyers info. 3
FullArmor Posted September 23, 2023 Author Posted September 23, 2023 How to get sprocket teeth mesh perfectly for for gluing. 7 1
GazzaS Posted September 25, 2023 Posted September 25, 2023 Welcome to the forum! Nice work on an interesting projekt. 3 1
FullArmor Posted September 25, 2023 Author Posted September 25, 2023 Just realized that i forgot to drill holes to upperhull. And drill marks are inside. Pro tip...use flashlight to luminate inside 7 1
GusMac Posted September 25, 2023 Posted September 25, 2023 Great solution, just need 3 hands to hold everything while you drill them out. 😁 3
FullArmor Posted October 1, 2023 Author Posted October 1, 2023 Building sidearmour. Does anybody know are these reactive armour or not? 3
Martinnfb Posted October 2, 2023 Posted October 2, 2023 Reactive indeed, to counter HEAT rounds and such. Looking good 👍 2 1
FullArmor Posted October 7, 2023 Author Posted October 7, 2023 Please help! How is this possible. Should i build a jig? 3
