Thanks Chris!  Hope you're feeling better.
I'm down to the last few decals, then will add some weathering and highlighting/shading, before adding the rigging and hopefully calling it done.  I'm a little nervous about pulling off the masks for the windows, so fingers crossed there.  I've also got a base I need to finish, along with a small CMK US Navy pilot.  Hopefully all that is doable tonight as my oldest has a tournament tomorrow.
Finish line is in sight.  Finished adding the decals, did a little shading/weathering, and just sprayed a final semi-gloss coat.  Just need to rig, add the props and canopy antennae, and maybe add some last bits of weathering for things like the wheels.
Thanks for looking in!
Finally finished!  This thing has been fun, but a bit nerve wracking.  There are so many PE and other fragile detail pieces, that I kept breaking things off.  I figured out a way to hold the model, but one time I accidentally held it a little too firm a popped one of the windows into the fuselage - let's just say, I said a few not so nice words 🤬  Somehow, after shaking the fuselage for a few minutes, the window popped back down into the slot.  It took a while, but I managed to get it glued back in.  It's not perfect, but better than terminating the build.
Thanks to everyone for your support and help!  Looking forward to the next GB!
I found a 1/72 scale Navy WW2 pilot from CMK and a picked up a resin concrete tarmac off of eBay the other day, so decided to use them for a simple diorama with the JRS-1.  I like adding figures to help better show scale.  Here, the figure shows how big this plane was.
Mike
Congratulations on not only crossing the finish line before the stoke of twelve but the Big Sikorsky looks incredible - what a build. WOW!
I was on board for the entire journey and you certainly had a mountain of roadblocks to overcome. The results speak for themselves - simply a stellar build. Surely looks as if all the finger crossing paid off in the end when the masks were removed.  I thoroughly enjoyed being onboard, start to finish.
Beautiful work and a build worthy of Queen of your Display Case. 🏆🥇🏆🥇🏆
