So I picked up an MDC Typhoon kit recently. Taking a quick look through the box everything seems to be there. Then I couldn't resist and held the two fuselage halves together and found maybe a slight challenge to the fit.
Any suggestions? Would the hot water trick still work? The kit is reasonably old so does resin get brittle with age the way plastic can?
Or do I just build it as the rarely seen split tail variant?
  • Confused 2
They all seem to be like that one way or another, the nose on mine did not line up and one of the wings was a bit wonky as well, hot water and brute force seems to be the answer.
The nose took some persuading as the top of the fuselage halves did not line up.
And there was air bubbles in various places, but it all worked out in the end.
Dennis
At least with the way it's bent it'll pull back to the centre line. Might have been harder if both halves had been bent the same direction. Still a pain though...
Dennis
Thanks Dennis. That's good to know. I think it may be due to the fuselage halves being so thin.
2 hours ago, belugawhaleman said:
Would using a hair-dryer work?
Paul, I hadn't thought of a hair dryer. I have one at my bench for decals so I can give that a try.
Gus, that's a good point. At least the halves seem to be the same length. That wasn't the case with the HpH Me410 I had.
Yes I had a problem with that by the cockpit, the finish was not too good either as you can see, I had to polish the wings up as they were so rough.
The full tale of the build is here, from way back in 2013 https://www.britmodeller.com/forums/index.php?/topic/234950125-mdc-hawker-typhoon/
Dennis
Dennis
Thanks Dennis. I see yours has the same crack in the fuselage mine does which adds to my theory that maybe the fuselage was a bit too thin.
