I've decided to start another '110 NF model from Eduard. A little bit different from the 1st one but still quite similar.
I just received this Profipack kit and was surprised its different from the one I just finished. A different kit number from the other. 8206 on the first kit and 8208 on this one. It also has different decals and radar aerials plus parts for another 110 a/c. I didn't notice the different kit number when I ordered it from Scale Hobbyist but I'm pleased with the kit and am ready to get with the program! 🙂
I don’t remember the designations, even after having read about them in a Ju-88 book a couple months ago, but the different radar antenna are different radar equipment. The radar range is different. The first iteration of this model had the antenna elements vertical. Then the Brits introduced “Window”, dropped aluminum strips. The Germans then found that rotating the elements 45 degrees, like in the second picture, lessened the effect of “Window”.
After looking over the available color schemes for this kit I think I'll change my mind from the one I had originally planned to do to this one.
CHANGE OF PLAN.....I did some test fitting on the extremely delicate antennas and, after MUCH fiddling and cussing, I broke some of the little aerial ends off while trying to get them straight.🙃 I had my doubts about those aerials in the first place. Now it's back to the original plan for the one marked C9 * IK.
32 minutes ago, mark31 said:
Nice i need to build my 110 some day.
Already years in the stash with conversion kit in 1/32
I built that Revell 1/32 kit many years ago. If I remember correctly it was a pretty good kit. 🙂
33 minutes ago, FullArmor said:
Lots of small gages🧐
Nice PE instrument faces. 🙂
46 minutes ago, Peterpools said:
John
Fantastic progress: front office looks so good and you're now already up to priming, which looks smooth as silk.
:construction:
Coming along pretty well Peter. 🙂
There is a bit of a fit issue I will have to address.
1 hour ago, KevinM said:
Looking Good to my eyes John you'll have cranked out and decaled by sunset tomorrow....:)
Thanks Kevin. Maybe not quite that soon but not too long. 🙂
Looking slick as a wet cat!;)
LOL Pretty slick alright! I really like that Xtracolor as it always sprays nice and smooth. Plus, being glossy, there is no need for a overcoat of clear gloss. 😀
2 hours ago, Peterpools said:
John
Right with Kev, paint work is looking brilliant.
:construction:
Thank you Peter. 🙂 Ya just can't go wrong with Xtracolor.
