Hi all,
Albatros D.V, Serial No: D.2006/17 as flown by Ltn.der.Reserve Bernhard Kilian of Jasta 21b during September 1917.
Thanks for your comments and support during this build.
As usual my web site has a fully detailed PDF build log, which can be downloaded from the 'Logs' page.
Mikes WW1 Aircraft Models
Mike
DV12jpg
Fantastic result as always Mike, Finish and figure are spot on. My only micro critic is about the flare pistol. I guess, nobody would have left it there barely balanced.
Hi Rob,
You can't see it but the flare pistol is actually on a mounting.
The barrel of the pistol is in the tube of the mounting. 😉
Mike
