Artful69 Posted December 27, 2015 Posted December 27, 2015 Hi All ... Just a couple of quick questions: I've been told that I need to wash the resin before I work with it, so: * Will normal dish washing soap be ok? * How hot/warm does the water need to be? * Will I need to scrub the parts with a brush or just immerse them ... and if so, for how long? Also ... I don't normally "prime" my plastic before painting - with Tamiya acrylics ... * Do I really have to prime the resin or the photo etch? * Will Tamiya acrylics stick to either properly? Rog
Administrators JeroenPeters Posted December 27, 2015 Administrators Posted December 27, 2015 Hi Rog, to be brutally honest i don't wash my resin and when i prime its usually a deep dark tamiya grey. But maybe I'm not the best person to take modeling advice from 1
wackyracer Posted December 27, 2015 Posted December 27, 2015 Me neither. Just prime with a plastic car bumper primer (Nice and cheap) 1
Administrators JayDee Posted December 27, 2015 Administrators Posted December 27, 2015 I sometimes wash it. If it appears to be a little oily, then always. Eduard and CMK (Artillery in new Fly Wessex kit), all ok. 1
Artful69 Posted December 27, 2015 Author Posted December 27, 2015 Like Jim said, if oily - wash. I normally don't either. But like Aaron I prefer automotive primer too in combined PE / plastic / resin builds to get a good and even paint-holding surface on the different materials - I use the Halford's yellow/green car primer type. Put the spray can in a bucket of warm ( not too hot ) water and shake very well. The higher temperature will give more pressure and control and a finer spray. ( Dry the can thoroughly with a kitchen cloth before use - you do not want water droplets on your sprayed piece...) Or, much to be preferred, you can use this primer decanted in the airbrush, as in: take an empty airbrush paint bottle and spray the stuff in straight from the can until the bottle is about half full, then add a little normal cellulose paint thinner at about 10 or 15 % and mix well. This will cover PE, plastic or resin with a tough and nice even semi matte coat. In both methods: Spray very thinly, adding thin layers until you have even covering - do not try to cover in one go but wait about 30 sec / 1 minute for the next pass. The resulting coat is ideal for painting in enamels or acrylics. Here's an example - plastic, resin and PE all neatly and evenly covered and ready for further painting ... Thanks George ... Haven't a lot of time to post a reply due to the build ... I grabbed a couple of Tamiya Primers while I was out at the hobby supplier yesterday (I needed a few things, so I just added some primer to the list) Also, I have to pop by the panel repairer with my car this week to get something sorted, so I'll ask the question about tinned automotive acrylic gear while I'm there also!! Rog
