Trigger Posted September 8, 2016 Posted September 8, 2016 Look what landed at my doorstep! The long awaited Cardoor version of the Typhoon. This one will be my new work in progress for the coming months. Couldn't resist to place its bubble top brother in front of the box. Lets see what is different in the box....... No more distortions in the clear parts or cracks, looks very good. The car doors are also on the clear parts sprue The extra Z sprue containing all the parts that are different from the bubble top version The hispano guns can be mounted either with or without the protective shrouds. The cockpit is on the inside a little different, and more is visible now, so that is certainly an improvement if you want to show parts of the cockpit. There are various versions of the canopy possible, i still have to decide what version. So it is time to commence with this build and add a Typhoon to my "squadron". iI will try to do regular updates on this build, lots of the construction is very much the same. I have ordered some aftermarket stuff from Eduard for the interior, because now more will be visible through the car door, and also the Master Hispano's, will look great without the protective shrouds. Well, i will get some styrene on the table now and start the build! That's it for now, Cheers, Frank 3
Wingco57 Posted September 9, 2016 Posted September 9, 2016 Hi Frank, Thank looks very nice. I would have thought Airfix would unveil this at Telford. Good timing. Looking forward to see your build. Nice bubble top builds too.
morley bill Posted September 9, 2016 Posted September 9, 2016 Built the first one great kit looking forward to your build Bill..
Administrators JeroenPeters Posted September 10, 2016 Administrators Posted September 10, 2016 Nice! Thnx for the comparison!
Trigger Posted September 25, 2016 Author Posted September 25, 2016 Hello, Some progress made on the Typhoon, basically everything is the same as the bubble top version, except for the pilot seat, I have closed up the hole that keeps the oil tank in place in the firewall, now the fire wall is nice and smooth looking, also closed the cross hole to align the engine against the firewall, now i have a little bit of clearance to play with when mounting the chin radiator. Also placed a few parts on the firewall sooner than the manual says. Normally you should place those parts with the engine in place, but by then it is very hard to place them. Also i gave the firewall a wash with some oils Weathered the pilot's seat, For this build i used the Yahu instrument panel, looks very good in my opinion, i just made the cables at the back of the panel with some lead wire, and beefed the panel up with some black plasticard, otherwise it would loo a little thin. I also bought an interior upgrade set from Eduard especially for the car door version, The set includes the window regulator handle that is not provided for in the kit and some door frames in photo etch, I am going to build the version with the white nose, but because this is an early version of the Typhoon, it didn't have the fishplates on the tail section for reinforcement, so i have to remove them from the frame, Fish plates on Fish plates removed Described an riveted, not entirely satisfied with the result, so i wil go over that again, and after a bit of primer and sanding it will look allright (although sanding in that area is a real challenge with all that detail and panel lines) I am now working on the rest of the cockpit, the throttle box, steering column etc. I have also bought the upgrade set from Eduard for the landing flaps, since i am going to build it with the wheels and flaps down. Well that's it for now, Let me know what you guys think, every comment is welcome and appreciated, Cheers, Frank 5
AlgiaNick Posted October 18, 2016 Posted October 18, 2016 Nice start!! Lovely detailing!!! I wish the best, to continue and finish it!!! Best Regards Nickolas 1
Administrators Fran Posted October 19, 2016 Administrators Posted October 19, 2016 Looks fantastic! love the detail! 1
Trigger Posted October 19, 2016 Author Posted October 19, 2016 Hello, Thanks everyone for the comments, i haven't done a lot i must admit, managed to get the engine in and i am detailing it a bit further, I will leave the portside uncovered and the starboard side covered. Also i will show one gun bay opened and will detail that further, (bought the excellent eduard hispano canon set to do this, the detail is stunning) also i am in the process of making my own spark plug leads, so i can show this on the port side as if the spark plugs are being replaced. (they really didn't have al long service life, i believe they had to be replaced after every thirty hours of flight), imagine replacing 48 spark plugs regularly, those ground crews really had a hell of a job keeping those aircraft in the air. Making spark plug leads is pretty labour intensive, first i punched out 48 hexagonal nuts, because the leads end up in a sort of jacket with a nut on top and that is being plugged on to the spark plug. I managed to buy spark plugs from rb motion and i have placed them in to the sabre engine. Also i have further detailed the cockpit withe the side control panels using the eduard pe set.Normally i wouldn't do this, but with the car door version much more of the cockpit is visible with the door opened, it would be a shame if this would go to waste. I have alos opted for some white metal landing gear oleos, as the ones in the kit are not strong enough for my taste and can snap of easily. enough said, here are some pictures, Also working on the electrical wiring using braided hoses with lead strips to clamp them in to place, still a work in progress. When you compare the eduard parts versus the kit parts, than you can see the difference Well that's it for now, hope you like it, Frank 3
Administrators James H Posted October 23, 2016 Administrators Posted October 23, 2016 Mine is now started too, so watching this one. It still worries me when you see how you have to force open the fuselage frames to add the seat bulkhead. It sort of looks wrong, but of course it isn't. 1
Maurice Posted December 29, 2019 Posted December 29, 2019 Ok. I am 57 & have not built an aircraft kit since I was 17. A 1/32 Revell Sopwith Camel. This Christmas a 1/24 scale airfix car door Typhoon turned up from my wife. Am a bit daunted. Anyone got any advice? 1
