mark31 Posted August 22, 2022 Posted August 22, 2022 Hello i have a problem with set and sol decalsetting the decals that i use are from cartograph and the dondt react with set and sol. What can be the problem? Thanks Mark 1
belugawhaleman Posted August 22, 2022 Posted August 22, 2022 On 8/22/2022 at 6:42 PM, mark31 said: Hello i have a problem with set and sol decalsetting the decals that i use are from cartograph and the dondt react with set and sol. What can be the problem? Thanks Mark Expand What type of decal solution are you using? 1
Bomber_County Posted August 22, 2022 Posted August 22, 2022 Bizarre I’ve used MicroSol and Set on Cartograf decals, how old are the bottles? 1
mark31 Posted August 22, 2022 Author Posted August 22, 2022 On 8/22/2022 at 7:14 PM, belugawhaleman said: What type of decal solution are you using? Expand Microscale Mark 1
mark31 Posted August 22, 2022 Author Posted August 22, 2022 On 8/22/2022 at 7:17 PM, Bomber_County said: Bizarre I’ve used MicroSol and Set on Cartograf decals, how old are the bottles? Expand Maybe a year But i have used them 2 weeks ago on other decals and also from cartograph and no problems Just with this set Mark 1 1
belugawhaleman Posted August 22, 2022 Posted August 22, 2022 On 8/22/2022 at 7:17 PM, mark31 said: Microscale Mark Expand For sol, I've used walther's Solvaset with good results. Also Tamiya makes decal sol in various Strengths.....Mark fit... Try one of the stronger ones. 1
mark31 Posted August 22, 2022 Author Posted August 22, 2022 On 8/22/2022 at 7:20 PM, belugawhaleman said: For sol, I've used walther's Solvaset with good results. Also Tamiya makes decal sol in various Strengths.....Mark fit... Try one of the stronger ones. Expand Thanks Will do Mark 2
Peterpools Posted August 23, 2022 Posted August 23, 2022 Mark Pretty strange as I've never had any issues at all with Cartograf decals and Micro Set and Sol. Right now, I'm decaling the IP for the Whirlwind with the supplied Cartograf decals and am using Mr Setter and Softer and no issues at all. 1 1
mark31 Posted August 23, 2022 Author Posted August 23, 2022 Every one thanks Thanks to 1 friend nearby i have another brand off setting and a strong solution and now it works Mark 1
Peterpools Posted August 23, 2022 Posted August 23, 2022 Mark I'm decaling the kit IP with Cartograf decals and OMG, yes, there seems to be compatibility issues. After reading your post, I went straight to Mr Setter and Mr Softer which are much stronger the Micro System and low and behold on the second portion of the IP decals, the Cartograf decals did not want to settle down and conform to the IP. I have never seen this before. There is a possibility that the decal run for the Whirlwind and Viggen were done at the same time and there might be an issue; who knows.
