JohnB Posted September 12, 2023 Posted September 12, 2023 I've been tinkering with this one off and on for three or four weeks. My old eyes have a difficult time with those smaller parts but I still plan to keep on it from time to time until I get it finished. I've always liked the FM-2's and feel that a good kit was long overdue. (Would be nice to have one in 1/32.) This is the one I plan to do. 4
JohnB Posted September 12, 2023 Author Posted September 12, 2023 I've been working on the framework that holds the oil tank and other items. VERY fiddly and has a fairly high cuss-factor (at least for me.) CA cement and Zip Kicker helps keep things where they are supposed to be. But it's going to need some cleanup. 🤪 6
Peterpools Posted September 12, 2023 Posted September 12, 2023 John Glad to see you tackling working in 48th scale every now and then, as Eduard makes some mighty awesome kits and the FM-2 is surely one of them. Just take your time and you will slowly start to get comfortable with the smaller scale. Agreed, it's a nice fill in, between 32nd scale builds. Front office looks so good and the start of the firewall assembly is coming along nicely as well. I've been making nice progress on the Airfix Sea Fury (update this weekend (🤞). Absolutely the opposite of your Eduard Wildcat in every respect. 3
JohnB Posted September 12, 2023 Author Posted September 12, 2023 28 minutes ago, Peterpools said: John Glad to see you tackling working in 48th scale every now and then, as Eduard makes some mighty awesome kits and the FM-2 is surely one of them. Just take your time and you will slowly start to get comfortable with the smaller scale. Agreed, it's a nice fill in, between 32nd scale builds. Front office looks so good and the start of the firewall assembly is coming along nicely as well. I've been making nice progress on the Airfix Sea Fury (update this weekend (🤞). Absolutely the opposite of your Eduard Wildcat in every respect. The smaller scale takes a lot of getting used to but I don't plan to make it my "main" scale although that was the case some years back. I look forward to your Sea Fury update. 2
Peterpools Posted September 14, 2023 Posted September 14, 2023 John Just takes some getting used to. I now tend to build in both scales and I'm still getting use to working in 48th scale, which for me has turned out to be a bit more difficult then 32nd scale. 1
JohnB Posted September 14, 2023 Author Posted September 14, 2023 1 hour ago, Peterpools said: John Just takes some getting used to. I now tend to build in both scales and I'm still getting use to working in 48th scale, which for me has turned out to be a bit more difficult then 32nd scale. I'm finding 1/48 a bit more difficult too due to the smaller size of the parts. So much harder to focus on than 1/32. 2
Peterpools Posted September 14, 2023 Posted September 14, 2023 John Absolutely the case and I found exactly the same. When I get frustrated, tomorrow is another day. It's a lot less frustration and a smaller learning curve with Tamiya and Eduard kits, as the parts fit. The Airfix Sea Fury is a whole different ballgame and is plagued with fil and molding issues - yup, a high cuss factor for sure. 1
JohnB Posted September 14, 2023 Author Posted September 14, 2023 2 minutes ago, Peterpools said: John Absolutely the case and I found exactly the same. When I get frustrated, tomorrow is another day. It's a lot less frustration and a smaller learning curve with Tamiya and Eduard kits, as the parts fit. The Airfix Sea Fury is a whole different ballgame and is plagued with fil and molding issues - yup, a high cuss factor for sure. Sounds like a candidate for the SOD Peter! 🤪 2
Peterpools Posted September 14, 2023 Posted September 14, 2023 John Fighting to keep it off the SOD 1 1
JohnB Posted September 14, 2023 Author Posted September 14, 2023 1 minute ago, Peterpools said: John Fighting to keep it off the SOD Good luck! 1
jep1210 Posted September 15, 2023 Posted September 15, 2023 Jumping on board to follow along. I have one of these in the stash and if not for a bunch of stuff already started I'd be tearing in to it. Yours is looking good so far. 2
JohnB Posted September 15, 2023 Author Posted September 15, 2023 53 minutes ago, jep1210 said: Jumping on board to follow along. I have one of these in the stash and if not for a bunch of stuff already started I'd be tearing in to it. Yours is looking good so far. Thanks. This is one I will be working on off and on in between other builds. Not a "primary" build right now. 🙄 1
JohnB Posted October 4, 2023 Author Posted October 4, 2023 While waiting for the paint to dry on the P-51 racer I decided to do some more work on this model. Well along now and it won't be long before I can paint the GSB. 4
Martinnfb Posted October 4, 2023 Posted October 4, 2023 Really nice work John, somehow I missed out on your progress. I heard only good things about Ed's Wildcat. Looking forward to the painting stage . 👍 3
JohnB Posted October 4, 2023 Author Posted October 4, 2023 1 minute ago, Martinnfb said: Really nice work John, somehow I missed out on your progress. I heard only good things about Ed's Wildcat. Looking forward to the painting stage . 👍 Thanks Martin. Since I haven't done any work on it since Sept. 15 (until today) there really haven't been many WIP's. Now, since it's about ready for paint, I hope to post some more WIP photos. 3
Peterpools Posted October 4, 2023 Posted October 4, 2023 John Nice progress on your Wildcat. She fills in beautifully in between stages on your large scale builds. 2
JohnB Posted October 4, 2023 Author Posted October 4, 2023 7 minutes ago, Peterpools said: John Nice progress on your Wildcat. She fills in beautifully in between stages on your large scale builds. Thank you. Nice to have a "standby" build sometimes. 2
JohnB Posted October 11, 2023 Author Posted October 11, 2023 This one is done and RFI: https://forum.largescalemodeller.com/topic/19688-eduard-wilder-cat-fm-2-completed/
