Getring the pilot in place with some work
Almost there.
Cleaning up one of the exhausts
And work on one off the wing pylons with the harm.
Mark
  On 2/16/2024 at 8:25 PM, Martinnfb said:
Looks like a nice kit, way better than the older offering.
Expand
yes indeed way better
the revell kit is more than 30 years old but whas a good kit.
only big problem whas the inakes now we have full lengt and also the slats and flaps are seperated so no need for the hunt for the paragon or flightpath set
  On 2/17/2024 at 2:17 PM, Peterpools said:
Mark
Making nice progress - the fit looks spot of as well. :construction:
Expand
Thanks Peter
I must say im impresed with the tooling italeri have done with this kit.
So far a bit off filler and no major fit problems just a bit off dry fit and sanding left and right.
Mark
Working on the base.
First time i have tryd to work with asphalt from ammo works good but iff you going to do it make the paste thinner before you are going to work with it.
Mark
Impressive work all around Mark. I really like the low altitude passing over tarmac with pilots in and lights on.
She's gonna be one large impressive Tonka when done . 😀
Could I offer a thought?, I found a while ago that putting subjects at an angle to the base often focused the attention more on them than the background and made for more a dynamic scenario , rather than having them square to it . Again just a thought .
  On 3/1/2024 at 6:59 PM, Martinnfb said:
Interesting approach, in order to replicate the asphalt surface, I am usually using black sand paper.
Expand
Thanks and yes sandpaper is also a option to do
Expand
Thanks its jus somthing difrent to do
Expand
Thanks for the tip will think about it for a next one.
Mark
Thank you all.
Not much done because troudle at work.
Doing more hours than the planning but going to find time for building.
Work off this day.
Pylons ecm pod and chaf dispenser.
Thats it for this update.
Mark
