I decided to come back to this build for a bit and try to sort out the problems I had earlier. I was able to get it together properly so now I can continue with the build. I plan to work on this and the Revell Spitfire simultaneously.
1 hour ago, BlrwestSiR said:
So, not quite Tamiya build quality. Glad you took the short break and have come back to it.
Some times you just have to step back and do something else for a bit. Hopefully things will go a bit more smoothly now. :)
10 minutes ago, Peterpools said:
John
Looking mighty good and I can't believe you're already onto the color coats. :construction:
Thank you Peter. It's going a bit faster than I expected. :)
Nice to see you back on this one John. The engineering complexity of this kit is what I was wondering about when I saw the CAD drawings for the first time. Not a Tamiya/Martin friendly kit for sure :)
Looking good and moving fast as usually .
Martin
Martin
I'm happy to be back on it Martin. I finished painting earlier and am in the process of decaling now. When all that's done I'll attach the gear and other items. I expect to have it finished in a day or two barring unforseen problems. :)
15 minutes ago, BlrwestSiR said:
Nice to see it cross the finish line.
For a short time that was a bit "iffy" LOL.
