On 8/25/2024 at 3:20 PM, denders said:
Pilots on a stick. Hmmmm. :blink:
By the Z-M instructions, the WSO is on the left and the Pilot is on the right. I'm not sure why the pilot needs both hands on the stick. Or at least it seems that way.
I think he's ejecting.... Too bad for the WSO...
5 hours ago, denders said:
I've added to the AM pile. Should be interesting.
The ResKit stuff is amazing - that detail is incredible.
Okay, Z-M/RedFox 3D printed IP parts installed.
First off, I had picked this up some time ago and this is what I used to glue the IP pieces.
All the pieces are installed except one. The WSO radar scope comes in two versions. One is if you want the scope visible, the other is for use if you're going to use the scope shroud. I decided to have the scope visible. Don't worry, the black piece isn't glued.
There are two items of note. The red mark is for the pilot's IP. The piece with the red circle is attached to the rest of the IP on the backing card and comes off with the main IP. It is printed to be able to snap out of location and be placed as shown. The Yellow mark, this piece has extra gray material which appears to be for the 'step' there, except it isn't made to snap off and I tried using my decal scissors to cut it off. As noted in the instructions, these items are very brittle. If you look at the upper left corner, some of it broke off.
I'm not sure what holds the pieces onto the backing card, but flexing the backing a little will allow a tweezer to go under the piece to lift it off the card.
So, I'll let these set for a day or so to let the glue cure. The next thing I want to do is spray some primer onto the pilot figures.
Dave
Dave
Nice work on applying the Red Fox Details. I'm going to buy a bottle of the Quinta 3d Decal Glue and give it a try as since I started using their decals years ago, my glue of choice has been Micro Krystal Kleer and I'm curious as to the difference in application.
:construction:
Dave, the parts look terrific! Nice work.  I also use MKK as well as Gator Glue and even Formula 560 for applying the Quinta decals so interested to see how yours turns out. BTW, what color gray did you spray your cockpit pieces?
Thanks, Chris! The interior is painted MRP-100 FS36231 U.S. and NATO interiors. It's the color called out in the instructions.
Thanks, Peter!
In assembling the cockpit area, it is necessary to make sure the parts are correctly located. This piece in the WSO pit, left side is just slightly out of place.
Meaning I had to do a little sanding on the outside of this assembly and put a small notch in some of the detail on the fuselage sidewall to make sure the fuselage halves matched up correctly.
It all looks fine though.
Ready to glue the fuselage halves together.
And glued together. The seats aren't installed yet, just sitting there.
And make sure to watch out for the intake turbulence generators and whatever that small thingy is on the starboard side.
Onward.
Dave
Thanks guys!
Next step. The projection on the right is molded into the part. The antenna in the center requires an 0.8mm hole to be drilled into the part and glued. The Antenna on the left is glued to the surface. I'm wondering how long 'til I knock it off.
Are we betting on minutes,hours or days?The office looks great by the way one day an Phantom will hit the desk.:D
I'm with you on the knock-offs.  I have two counterweights on flaps, as well as a long thin probe molded into the wing.  I'm figurein 10:1 odds that any of them last to the weekend...
Looking good, though.  Nice progress!
Well, two more steps involving the fuselage, and I haven't knocked anything off yet. :rolleyes: There wasn't much to those steps though.
There's a little bit of putty needed on the top of the nose at the seam and a bit more on the left side along the radome seam. Those little air intakes are a bit fiddly. I didn't put the pitot on the nose though.
Thanks, Peter and Martin!
Engines are together and painted. Most of the paint won't be visible, but..........
I also started assembling the intake trunks. I thought I'd see how it goes. I have the GT Resin parts too.
