RalphSarc Posted April 27, 2014 Posted April 27, 2014 I will be entering this Junkers Ju88A-4 modifying it into a Ju88C-6 Nightfighter R4+HH for the group build! Hope I do it justice!! 5
Wingco57 Posted April 27, 2014 Posted April 27, 2014 Very nice, the C- version is one sleek looking beauty. And sinister in black. Cees 1
Administrators JayDee Posted April 27, 2014 Administrators Posted April 27, 2014 Oh yes, another C variant! And you're using the same conversion as a couple of us too. Looking forward to watching this one progress 1
RalphSarc Posted May 10, 2014 Author Posted May 10, 2014 Well it's a rainy day in Georgia so thought I'd spend the day with my Revell Ju88 group build entry. Right of the bat the kit fit of the new kit is a thousand times better that the old Revell Ju88 kit. The fuselage parts are cleaner, better tooled and much nicer to work with. The bottom fuselage section was a snap to fit and glue using "extra thin" where in the old kit it was a bit of a struggle. The instruction are nicely done and the spur map makes it easy to locate parts. I use a yellow highlighter to check off parts as they are removed and installed assuring that I don't miss any. After a bit of modification and removel of the bomb site and support flooring that would normally show through the clear front I was able to dry fit the CMK Ju88C-2 nose conversion kit I purchased for this build. The fit is okay but some seam work and putty will be needed. Since this is my first attempt at using Edward interior instruments I quickly realized that grinding was involved to install them, lol!! I tried a soft foam file, no luck! I tried a steal file with limited success! Suddenly I remembered my shop grinder with a side sanding wheel down in my basement. Wow that worked perfectly!!! So after a fun filled afternoon using all the new skills I've learned and getting over a small amount of cutting, grinding and modifying anxiety here's where I'm at!! Hope to put a coat of interior gray tomorrow after I return from our Atlanta Model Show! 4
RalphSarc Posted May 10, 2014 Author Posted May 10, 2014 Getting ready to detail the Ju88 seats and Cees was kind enough to share some detailing and installation tips. Any other thoughts concerning detailing seats and the installation of seat-belts since this will be my first attempt would greatly be appreciated!!
Wingco57 Posted May 10, 2014 Posted May 10, 2014 Destruction before commencing construction. I like it. Cees 1
RalphSarc Posted May 10, 2014 Author Posted May 10, 2014 Destruction before commencing construction. I like it. Cees LOL isn't that the truth!!! The cutting, grinding and modifying anxiety was incredible and I had to remember to breath, lol!!
RalphSarc Posted May 10, 2014 Author Posted May 10, 2014 Started the seats today. First try at seat detail with seat-belts! Here goes!! Thanks Cees for the helpful suggestions.
Administrators JayDee Posted May 11, 2014 Administrators Posted May 11, 2014 Looking sweet. You should nail this. I did a test fit of the resin nose conversion on my fuse with everything taped up, and the fit should need barely any filler. Do a full dry assemble and re-fit and see if that's the case. 1
RalphSarc Posted May 11, 2014 Author Posted May 11, 2014 Looking sweet. You should nail this. I did a test fit of the resin nose conversion on my fuse with everything taped up, and the fit should need barely any filler. Do a full dry assemble and re-fit and see if that's the case. I agree a bit of filler will be needed but not much. Question :When installing the forward bottom gunners tub conversion section does the raised bits used to align the original tube need to be sanded smooth?? Ralph.
Administrators JayDee Posted May 11, 2014 Administrators Posted May 11, 2014 Not sure at this stage Ralph. I'd need to check, but I think I know what area you mean. I'm thinking they do as the resin is a solid part and not hollow like the plastic.
RalphSarc Posted May 11, 2014 Author Posted May 11, 2014 Not sure at this stage Ralph. I'd need to check, but I think I know what area you mean. I'm thinking they do as the resin is a solid part and not hollow like the plastic. James here's a picture of what I was asking about. I think the front alignment bits will have to be sanded smooth to allow the conversion piece to set flush with the underside of the fuselage. 1
Administrators JayDee Posted May 11, 2014 Administrators Posted May 11, 2014 I think you're right Ralph. That was what I thought you meant. Don't forget to only remove the part which coincides with the resin though. You'll still need some of it for the remaining gondola area. 1
RalphSarc Posted May 11, 2014 Author Posted May 11, 2014 Thought I'd post a few pictures of the out of the box cockpit detail I'm finding in my build of the new Revell Ju88. I guess from these pictures you can decide if whether or not to buy after market resin interiors. I did order seat-belts and self-adhesive instruments and panels. Will weather, paint, chip, apply cockpit placards, add seat-belts and seal next week. 2
RalphSarc Posted May 11, 2014 Author Posted May 11, 2014 Here's a question: did the Ju88's have seat cushions or did crews sit on their parachutes? I found some small cork and styrofoam squares and fashioned them into cushions. I think after weathering they'd look good with the seat-belts. After some weather and cushion marks using a sharp point. Still more work to be done. Trimmed most of the cork backing leaving the foam. Still needs some shaping!
RalphSarc Posted May 12, 2014 Author Posted May 12, 2014 Okay several hours of work have past and here's the results without seat-belts!! Another wash and sealer and the starboard side of the cockpit will be done. Oh by the way love my new Neo Airbrush. So much more control and detail possibilities over a spray can! Thanks again for all the kind help I've received from all on the forum, I'm pretty thrilled!! 4
RalphSarc Posted May 12, 2014 Author Posted May 12, 2014 Looking nice Ralph. Regards, Kent Thanks Kent. It's been great fun using all my new found modeling skills. I'm thrilled with my progress of the Ju88 so far. 1
efrick Posted May 12, 2014 Posted May 12, 2014 That is really, really looking nice Ralph! You have nailed the cockpit! Very convincing techniques you are using there! Regards, Ed 1
DougN Posted May 12, 2014 Posted May 12, 2014 Looks like you're off to a great start Ralph! Makes me want to drag out one of my Ju88's in the stash Doug
RalphSarc Posted May 13, 2014 Author Posted May 13, 2014 Looks like you're off to a great start Ralph! Makes me want to drag out one of my Ju88's in the stash Doug Thanks Doug. Yea it would be nice for someone to start their Ju88. I'm all alone :-(
RalphSarc Posted May 13, 2014 Author Posted May 13, 2014 Okay this afternoon and evening, with lots of breaks in between, was spent teaching myself to build and install Eduard Ju88 seat-belts!! After a fruitless internet search and YouTube search I decided I was a big boy and it was time to jump in with both feet!! Here's the results so far!! What do you think? 3
Administrators JayDee Posted May 13, 2014 Administrators Posted May 13, 2014 You did a great job there Ralph. Those colour PE belts can be a pain in the ass, so some respect it due for installing them so well. This is looking really good. 1
