kahunaminor Posted June 24, 2014 Posted June 24, 2014 Hello all, Here is my latest WIP. I have had it on the bench about two months and slowly getting through it. As I approach the end, I have finally uploaded the photos, so it will be a shortened WIP. More to follow Regards, Kent 2
kahunaminor Posted June 24, 2014 Author Posted June 24, 2014 Part deux... More to follow, Regards, Kent 2
kahunaminor Posted June 24, 2014 Author Posted June 24, 2014 Still here??? More of the progress... So that's where I am at the moment. Thanks for looking. Regards, Kent 3
RalphSarc Posted June 24, 2014 Posted June 24, 2014 Wow super job so far. Really like the camouflage work!
Matt_ Posted June 24, 2014 Posted June 24, 2014 Nice work, gotta love it with that unit badge.. Matt 1
BevanBrooks Posted June 25, 2014 Posted June 25, 2014 Nice! How did you go with the upper wing to fuselage join? Cheeers Bevan
rieser Posted June 25, 2014 Posted June 25, 2014 Cool! Hope its been a pleasant project. Not far from the end now - looking forward to seeing the end result. What's the go with the undercarriage mod? Cheers, Ralph. 1
kahunaminor Posted June 25, 2014 Author Posted June 25, 2014 Cool! Hope its been a pleasant project. Not far from the end now - looking forward to seeing the end result. What's the go with the undercarriage mod? Cheers, Ralph. There is a fix list for the E-1 that Thierry Laurent has put together over at LSP. I based some of the fixes here on that list. One is the oleo are 2mm too long, giving a more "gangly" appearance to an already gangly stance. Apparently it is fortunate the MLG leg is the right size because cutting off the oleos and retraction struts allows you to shorten them by 2mm, giving a better sit. It has been quite pleasant and thus far a relatively stress free build but there is the weathering to come next and my nemeses, the exhaust stains. Although from period pictures these appear to be better maintained in 1940 than the later war era 109. Thanks for looking in. Regards, Kent
kahunaminor Posted June 25, 2014 Author Posted June 25, 2014 Nice! How did you go with the upper wing to fuselage join? Cheeers Bevan Thanks Bevan. The upper wing fuselage wasn't that bad. Some fenagling and Tamiya thin a little at a time. The lower wings and rear fuselage was a nightmare. There was a step a mile wide at the curved area where it moves onto the fuselage sides. I don't think I "nailed" it but I am close. As you can hopefully see it's close. Regards, Kent 1
kahunaminor Posted June 28, 2014 Author Posted June 28, 2014 Thanks for all the positives fellow modellers, it is appreciated. I thought I would show you a quick progress of the wheels. The kit wheels are not good so I purchased a set of the Eagle Editions and a set of Eduard Brassin for comparison. The EE look mile ahead of the kit supplied but I went with the Brassin for this build. Brassin are interesting in they give you one set of wheels but two sets of hubs. The first are a one piece affair and the second a two piece. I went with the kit tyres and the two piece Brassin. And here is where we are after a Flory's (ProModeller) dark dirt wash and a coat of rattle can Dullcote: I'll let that set up overnight and then maybe another round of Dullcote and some more subtle weathering. I am at the point now where I have to seriously resist taking the masking off the canopies! Regards, Kent 1
BevanBrooks Posted June 28, 2014 Posted June 28, 2014 In the home straight now, looking good. Cheers Bevan 1
kahunaminor Posted June 28, 2014 Author Posted June 28, 2014 In the home straight now, looking good. Cheers Bevan Thanks Bevan. This is the point I generally race to the finish and bugger something up.... Kent
rieser Posted June 29, 2014 Posted June 29, 2014 Great to see the progress Kent. A colourful and unusual scheme - well worth having a go at. Can I ask who's points you used for the camo colours? In the earlier pics they look too matte to be Gunze acrylics. Cheers, Ralph.
kahunaminor Posted June 29, 2014 Author Posted June 29, 2014 Great to see the progress Kent. A colourful and unusual scheme - well worth having a go at. Can I ask who's points you used for the camo colours? In the earlier pics they look too matte to be Gunze acrylics. Cheers, Ralph. Thanks Ralph. The paints are Aeromaster warbirds enamels for the 02 and 65 that I got off the guy in the US on Evilbay. The 71 is the Humbrol enamel from their new line of RLM enamels. It stays flatter than the Aeromaster, even under a couple of gloss coats! Thanks for stopping by. Kent
kahunaminor Posted June 30, 2014 Author Posted June 30, 2014 Second coat of Dullcote has gone on and the canopy masks have come off!! Happy with that effort. Regards, Kent
rieser Posted June 30, 2014 Posted June 30, 2014 Thanks Kent. I've had some strange results with the Gunze RLM acrylics. Spray beautifully; decal/seal/weather/seal/flat coat the model; come back 6 months later only to find very fine cracks in the paintwork. Will try some home-mixed 71/02/65 from Tamiya acrylics for the next one. Cheers, Ralph.
kahunaminor Posted June 30, 2014 Author Posted June 30, 2014 I got a bit of a rush to the head and installed the antenna wire. Stretched EZ line with CA blobs for insulators and a brass wire "spring". Made a cone for the wind deflector out of stretched card. Then added the wheels: Thanks for looking. Kent
kahunaminor Posted July 3, 2014 Author Posted July 3, 2014 End run time. I have completed the build. Canopy attached and an EZ line, coiled spring attached. Wheel covers on. ID lights on the wing tips and a 1mm "little lens" for the rear light. Thanks for the comments and support. I will tray and get some "glamour" shots on RFI shortly. Regards, Kent 1
