609DAF49-BA16-4470-BA3A-CEE22D588A76_zps
9156B42F-EB04-4DEF-A4D5-0B67C2319526_zps
Finally it's arrived! I only had chance for a quick scan but it seems excellent!
Thanks to Kagemusha's heads up I got the donor HK F.4 for £55 delivered from lucky model so it's cost about £120 all in so not to bad at all for a comprehensive conversion.
Watch this space I'll post some more pics tonight.
Talk about 'hot of the press!!' Arrived this morning and briefly reviewed this afternoon - now that's what you call a dedicated LSM reviewer!
It looks terrific and I'm sure will result in a 'corking model' to go alongside the F.4 - can't wait!
regards,
Dad
Now that looks good and seems to offer 'plenty of bang for your buck'!! I've built - yes and finished! - the Paul Fisher's Hunter T.7 and I thought it was amazing - may even do another!
Looking forward to the build!!
Regards,
Dad
Hiya Ben,
             That`s a nice conversion set and it should result in a great model but as a fellow Lancashire lad you should really be going for the 611 (West Lancashire) Sqn option based at Woodvale!
             Tony
Hiya Ben,
Tony
Blimey didn't realise that. Might have to do that for old times sake.
611 Sqn operated F.8`s in silver and in camouflage,......... so either would be OK, but the camouflaged ones with the later fully glazed canopy do look very nice indeed!
          Tony
PROGRESS!!!
Got chance to do a bit tonight so thought I'd break the back of it and do the two main cuts.
Dymo tape was the trick here to keep the cuts straight and accurate and I used progressively bigger scribers until I could use the razor saw.
F9D0F60E-8469-4937-A43A-8D3564DCB1FB_zps
FF55247B-0341-468C-B577-960DE12207A9_zps
Not a lot left of the kit fuselage!!
CAC46AC7-2F38-4D22-A09F-C2B8663008DC_zps
535E5E25-FD77-4C30-9D73-EFF0EFF64F00_zps
A1F511DE-3689-4197-8CC5-D2E6CE729303_zps
1BC732D5-B25C-41AA-BB15-D6C09CCB2708_zps
Lots of excess plastic!
071392C9-6952-4C08-9C93-54A9FD9EBCCD_zps
351CC24A-E6E4-4502-BC9D-8DCEAC0F6AA5_zps
2D586E37-114E-4B88-887A-9720DC7A9D8F_zps
F0748AC4-E69A-4D63-8DDF-F574548AE111_zps
Guest Kagemusha
Pity they didn't just do a full fuselage, hope they do for the FR.9 and nightfighters. Good luck with it, great project.
Hardly seems worth using that little of the kit fuselage, gonna be bugger all left of the HK kit for the two seaters!
Done all the major cutting now, fits pretty good, especially as I haven't done any cleaning up yet.
345B2B85-F343-4CE0-8DCE-474B3B62F532_zps
8AFBAA4C-4EA2-4317-AF38-750D8982031D_zps
Right haven't had a lot to report as I've mainly been cleaning the resin up, but I sprayed the inside of the intakes silver today and that's allowed me to get the wings together. The way the resin intakes are cast means you can't put them in place once the wings together, so I've glued the wings and left the intakes loose and I'll Super glue them tomorrow once the plastic has fully dried. I also added a bit of wiring and piping to the intake faces to add some interest for anyone daft enough to look inside.
464C4C3F-CD99-47B7-A1DA-412FFE2DD230_zps
D23B3602-4278-46CC-AA8E-33022FAC6598_zps
58A719E5-B0A0-46CD-A4AF-3AA4C2C1C94B_zps
You might also notice that the tails on, I cut it off as accurately as I could with dymo tape and used a sanding block to make sure the mating surface is truly square but i have a slight step between the two. After a first attempt I plugged the kit fuse with two part epoxy putty and added a brass rod to give it some strength and allow me to take my time adjusting it. I'll be interested to see how other modellers fair and wether it's my shoddy cutting or slight shrinkage.
CCC12C7D-9B9A-4443-A698-90D5DE0B9004_zps
Ben,
It is always difficult to get a good fit with such sets. The brass tube you use will give strenght to enable you to make a good joint.
Cees
Its coming on well Ben,.....have you decided upon a scheme yet,.....all green or silver and black?
           Tony
Tony
Not yet mate, I emailed a fella from the 610Sqn association who might have more pics. Waiting to hear back.
I'm having the same issue with the tail on mine. Removed plastic to the panel line and got a beautifully squared off joint. If I push the tail into each fuse half, the fit looks great, but when i put the fuse halves together and plug the tail in, there's a serious step.
I have a plan to fix mine, and I'll post it in my topic if it works.
  • 4 weeks later...
Sorry for the lack of updates fellas, managed to get the cockpit done, the ejection seat is excellent and a few airscale placards have livened up the "Coal hole". Found it quite hard to make the black interior interesting so scruffed it up a bit. Few more bits to do like the framing for the gunsight and the ladder structure over the ammo bay but I'll leave them off until the end so they don't yet damaged.
5DDB2DF3-7AD7-403B-81F1-1A75301BF7E2_zps
69E5804C-824F-44F6-B123-D91BF15AEF58_zps
847BE2AD-CDA0-4D09-A1D5-D08B9AC0AD45_zps
C0251A1A-355D-4EB1-9FAF-90633074E88C_zps
6ACA686D-885F-422A-8BAE-BED9339CFC0E_zps
3AEBE492-2480-4F4C-B3D6-595DACBD7EC4_zps
A6A041DA-3023-4812-ABC2-424ECBF2BE01_zps
