Members Mikester Posted January 2, 2016 Members Posted January 2, 2016 Well here's my second go-around on the Revell Erla G-10. I'm a little happier with this from an accuracy standpoint since addressing the MG cowl spacing makes a big difference. This kit builds up nicely out of the box but I had a lot of issues with filler not cooperating on me when I grafted the Hasegawa cowl section on, finally switched to gap filling super glue which did the trick and which will be my go to filler from here on out. The Aries cockpit also threw off the fuselage width so I had to insert some shim on the lower wing to close the gap which was no surprise since it was Aries. The aftermarket laundry list includes: Aries Cockpit HGW Seatbelts BarracudaCast Spinner and Propeller Blades BarracudaCast S/C Intake and Exhaust Stacks BarracudaCast Wheels BarracudaCast Small Wing Bump Inserts Quickboost MG Forward Cowl Section from a Hasegawa G-10 used to correct spacing of gun troughs on cowl. Eduard Brassin Landing Gear Paint as always is Mr. Color and markings are Montex masks and kit decals. 9
Administrators JeroenPeters Posted January 2, 2016 Administrators Posted January 2, 2016 Dang mike... super sweet.. Tell me: how many models do you build in a month (normally i would ask: a year) I love it. 1
Members Mikester Posted January 2, 2016 Author Members Posted January 2, 2016 On 1/2/2016 at 6:02 AM, JeroenPeters said: Dang mike... super sweet.. Tell me: how many models do you build in a month (normally i would ask: a year) I love it. Thanks Jeroen! I do four a year like clockwork. I wish I could get more in, I'll shoot for five this year!
BevanBrooks Posted January 2, 2016 Posted January 2, 2016 Another fine build there Mike, fantastic result. I've got the small wheel bulge inserts for my G10 from Barra and gotta say not the best fit. I double checked with the kit plastic, no probs......... did you have any issues at all. Not complaining, maybe just one of those things. I am however building the wings up as separate units to slide on after like Hasegawa for ease of riveting but still find the kits plastic to be a better fit. We've had some extremely hot days here in the last few weeks so may have caused some srinkage? Anyway I'll stop rambling now.. Cheers Bevan 1
Members Mikester Posted January 2, 2016 Author Members Posted January 2, 2016 On 1/2/2016 at 8:02 AM, BevanBrooks said: Another fine build there Mike, fantastic result. I've got the small wheel bulge inserts for my G10 from Barra and gotta say not the best fit. I double checked with the kit plastic, no probs......... did you have any issues at all. Not complaining, maybe just one of those things. I am however building the wings up as separate units to slide on after like Hasegawa for ease of riveting but still find the kits plastic to be a better fit. We've had some extremely hot days here in the last few weeks so may have caused some srinkage? Anyway I'll stop rambling now.. Cheers Bevan Bevan, I did have some issues with the wing inserts. I wish the casting block would have been outboard rather than inboard, I think this would have simplified things considerably since it would have given you a nice flat surface to mate up against the fuselage. They sat a little high too but that could have been my fault. Next time I do an Erla G-10 with small wing bulges I'm just going to use a G-6 and the AMUR Reaver nose, I think that's the easiest, most accurate route on this one. 1
Mauricio_1971 Posted January 2, 2016 Posted January 2, 2016 Beautiful, Mike, she stands proud. And scheme is extremely attractive. Is there a big difference between kit's wings and Barracuda Inserts to justify the pain? Can we see pictures from other angles (Top, Bottom) to appreciate the whole package, Cheers Mauricio 1
Members Mikester Posted January 2, 2016 Author Members Posted January 2, 2016 On 1/2/2016 at 7:11 PM, Mauricio_1971 said: Beautiful, Mike, she stands proud. And scheme is extremely attractive. Is there a big difference between kit's wings and Barracuda Inserts to justify the pain? Can we see pictures from other angles (Top, Bottom) to appreciate the whole package, Cheers Mauricio Mauricio, Thanks! Many Erla G-10 aircraft were actually fitted with the smaller wheels and corresponding smaller wing bumps, the wing bumps included in the kit are the larger style.
AITORAZKUE Posted January 8, 2016 Posted January 8, 2016 I like it Mike..!....the "late" airplanes are my weakness....and your camouflage is cool and..well defined...Good work.. 3
